Re: Building Workspace has encountered a Problem [message #1753556 is a reply to message #1753332] |
Tue, 07 February 2017 17:16 |
Ernesto Posse Messages: 438 Registered: March 2011 |
Thanks for reporting this. We are aware of these problems.
They are in fact separate issues.
First, the "Top capsule not found" is a known bug (see https://bugs.eclipse.org/bugs/show_bug.cgi?id=511247). Until this bug is fixed, the only workaround is to close the model and reopen it.
The problem with "building the workspace" is not actually a Papyrus-RT bug but a bug in the CDT. Unfortunately we cannot do anything about it, as we do not control the CDT.
Disabling the "Build automatically" will spare you these errors, but you may encounter them again if you build your workspace. Also, if you disable them then you will loose the synchronization between CDT editors and Papyrus-RT models, if you use it (this is, when you select a state or transition and choose Edit effect, Edit guard or Edit action, a CDT editor will open where you can directly edit the associated code, and this will be synchronized with the model, as long as "Build automatically" is checked).
FUDForum. Page generated in 0.03644 seconds
