Re: [EMF Forms] Instance model changes in e4 [message #1753522 is a reply to message #1753509] |
Tue, 07 February 2017 12:41 |
Thorsten Arendt Messages: 18 Registered: June 2013 |
Hi Jonas.
1. Setting the breakpoint verified that the getter is not called when editing the attribute (it is called only during loading the instance).
2. I do not exactly understand what you mean by the databinding advice. As far as I know provides EMF Forms the data binding implicitly when using 'ECPSWTViewRenderer.INSTANCE.render(content, myEObj)', so I did not implement a data binding explicitly.
3. Yes, adding both variants was for testing purposes.
4. The console says the following; maybe it's important:
!ENTRY org.eclipse.equinox.ds 1 0 2017-02-07 13:29:59.501
!MESSAGE Could not bind a reference of component org.eclipse.emfforms.swt.core.rendererfactory. The reference is: Reference[name = EMFFormsAdditionalRendererService, interface = org.eclipse.emfforms.spi.swt.core.EMFFormsAdditionalRendererService, policy = dynamic, cardinality = 0..n, target = null, bind = addEMFFormsAdditionalRendererService, unbind = removeEMFFormsAdditionalRendererService]
!ENTRY org.eclipse.equinox.ds 1 0 2017-02-07 13:29:59.524
!MESSAGE Could not bind a reference of component EMFFormsViewService. The reference is: Reference[name = Provider, interface = org.eclipse.emf.ecp.view.spi.provider.IViewProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addProvider, unbind = removeProvider]
Thorsten
FUDForum. Page generated in 0.04318 seconds
