Home » Modeling » Papyrus » compile Papyrus source code(how to setup the dev environment and compile Papyrus source code)
icon9.gif  compile Papyrus source code [message #1753290] Fri, 03 February 2017 10:38 Go to next message
xiaocong li is currently offline xiaocong liFriend
I want to change some Papyrus code and compile.
When I try to setup the dev evnironment following the Developer Guide, I get some errors.
The picture below shows how I config the environment.
index.php/fa/28326/0/
When it comes to the step shown below, there are errors shown in file 'errorEclipse.txt'.
index.php/fa/28328/0/
Then I click the back button and finish button again, it can successfully setup the environment but there many errors as shown below
index.php/fa/28330/0/
I also try to clone the git repository and use 'mvn clean verify' to compile the code, I get error shown in 'errroVPS.txt'
Can anyone tell me how to import source code to compile it please ?
Re: compile Papyrus source code [message #1753833 is a reply to message #1753290] Fri, 10 February 2017 14:00 Go to previous message
Géry Deloge is currently offline Géry DelogeFriend
From this file I see
java.net.UnknownHostException: hudson.eclipse.org
I suppose server was unfortunately down when you tried to fetch packages
The logfile says
Caused by: java.lang.OutOfMemoryError: Java heap space
try to increase maven heap memory size
Cheers
Previous Topic:SVG display
Next Topic:Multiple Inheritance in UML Profile
Current Time: Tue Feb 25 15:04:05 GMT 2020
Powered by FUDForum. Page generated in 0.08566 seconds
