Home » Eclipse Projects » Eclipse Platform » Oxygen M5 refuses to update
Oxygen M5 refuses to update [message #1752827] Fri, 27 January 2017 16:30 Go to next message
I did a new install.
However the "check for updates" fails with "no remedy".
Cannot complete the install because of a conflicting dependency.
  Software being installed: Eclipse Platform 4.7.0.v20170126-1030 (org.eclipse.platform.feature.group 4.7.0.v20170126-1030)
  Software currently installed: Eclipse IDE for Java Developers 4.7.0.20161214-1101 (epp.package.java 4.7.0.20161214-1101)
  Only one of the following can be installed at once:
    Quicklinks for the Welcome Framework 1.0.0.v20170104-1824 (org.eclipse.ui.intro.quicklinks 1.0.0.v20170104-1824)
    Quicklinks for the Welcome Framework 1.0.0.v20160515-0255 (org.eclipse.ui.intro.quicklinks 1.0.0.v20160515-0255)
  Cannot satisfy dependency:
    From: Eclipse IDE for Java Developers 4.7.0.20161214-1101 (epp.package.java 4.7.0.20161214-1101)
    To: org.eclipse.platform.feature.group [4.7.0.v20161208-1309]
    From: Eclipse Platform 4.7.0.v20161208-1309 (org.eclipse.platform.feature.group 4.7.0.v20161208-1309)
    To: org.eclipse.ui.intro.quicklinks [1.0.0.v20160515-0255]
    From: Eclipse Platform 4.7.0.v20170126-1030 (org.eclipse.platform.feature.group 4.7.0.v20170126-1030)
    To: org.eclipse.ui.intro.quicklinks [1.0.0.v20170104-1824]
How can I analyze this? Is this a bug? Do i have something installed that avoids this update
Was adding the update site: http://download.eclipse.org/eclipse/updates/4.7milestones
the problem?
Re: Oxygen M5 refuses to update [message #1752989 is a reply to message #1752827] Tue, 31 January 2017 12:18 Go to previous message
You can't typically update an EPP package to a milestone build. Yes, if you disable the 4.7milestones (Preferences > Install/Update > Available Update Sites[/em] and uncheck the site) then you should be ok.
Brian.
Previous Topic:"unable to retrieve the bundle ..." when Eclipse Neon2 is opening
Next Topic:Reuse keybinding to open another dialog
Current Time: Sun Apr 20 19:39:35 EDT 2025
Powered by FUDForum. Page generated in 0.03886 seconds
