Home » Eclipse Projects » EGit / JGit » contents of ~/.gitignore not used (global ~/.gitignore not being processed)
contents of ~/.gitignore not used [message #1752676] Thu, 26 January 2017 00:01 Go to next message
Michael Giroux is currently offline Michael GirouxFriend
I use Eclipse on a Mac system. I end up with lots of untracked .DS_STORE files in my projects.
I can ignore these by placing a .gitignore file in the root of each project, but Git already has a solution for this. I have a global ignore file at ~/.gitignore that works just fine when using command line Git, but the file is not respected when using Eclipse/Egit.
The Team/Git preferences do not provide a means to configure the user .gitignore file, so I'm thinking this is a limitation.
Is there something I'm overlooking? Is it possible to make EGit use the ignore list from the user ~/.gitignore file?
Re: contents of ~/.gitignore not used [message #1752752 is a reply to message #1752676] Thu, 26 January 2017 21:16 Go to previous message
Matthias Sohn is currently offline Matthias SohnFriend
did you add the following configuration to ~/.gitconfig :
[core]
excludesfile = <path to ~/.gitignore>
if not, this explains why it's not respected, see "core.excludesFile"
in ftp://www.kernel.org/pub/software/scm/git/docs/git-config.html
Previous Topic:git ssh push hangs with eclipse and tfs
Next Topic:Tracking the deletion of remote branches?
Current Time: Tue Oct 27 22:25:41 GMT 2020
Powered by FUDForum. Page generated in 0.01885 seconds
