Home » Modeling » OCL » collect equivalent for one element
collect equivalent for one element [message #1752332] Sat, 21 January 2017 18:05 Go to next message
Banafsheh Azizi is currently offline Banafsheh AziziFriend
I am new in OCL. How can I write OCL expression below for one element?
s.source.elements -> collect (s|thisModule.CreateMatchClass(s))
Member of MDSE Research Group
http://mdse.ui.ac.ir
[Updated on: Sat, 21 January 2017 18:06]
Report message to a moderator
Re: collect equivalent for one element [message #1752333 is a reply to message #1752332] Sat, 21 January 2017 19:01 Go to previous messageGo to next message
I have no idea, since I cannot understand your question.
Once you learn to express your intended computation in a clear (declarative) way you will find that transliteration into OCL is quite straightforward. Practice your exposition.
Ed Willink
Re: collect equivalent for one element [message #1752346 is a reply to message #1752333] Sun, 22 January 2017 18:45 Go to previous messageGo to next message
In other words, I don't understand which elements does the above code collect?
Since "collect" is used when we have more than one element, if I have one element (instead of elements), what changes occure to "-> collect (s|thisModule.CreateMatchClass(s))" part of that expression?
Re: collect equivalent for one element [message #1752348 is a reply to message #1752346] Sun, 22 January 2017 19:12 Go to previous messageGo to next message
collect is for multiple elements.
If you only have one element why would you want to collect all one of it? For comparison, if you have a Java loop counter, why would you declare it as "int[] i" rather than "int i", or why would you want to wrap a single calculation in a loop?
You need to express your intent clearly.
Ed Willink
Re: collect equivalent for one element [message #1752371 is a reply to message #1752348] Mon, 23 January 2017 06:36 Go to previous messageGo to next message
For one element is below code true?
s.source.thisModule.CreateMatchClass(s)
Re: collect equivalent for one element [message #1752384 is a reply to message #1752371] Mon, 23 January 2017 09:24 Go to previous messageGo to next message
No idea.
What is "s"?
What is "source"?
What is "thisModule"?
What is "CreateMatchClass"?
See https://wiki.eclipse.org/OCL/ForumNetiquette
Ed Willink
Re: collect equivalent for one element [message #1752440 is a reply to message #1752384] Mon, 23 January 2017 18:51 Go to previous message
I get my answer in another site. thanks for your time.
Previous Topic:Of surname propagation, another nest.
Next Topic:Problem in navigating references
Current Time: Sat Sep 21 22:02:56 GMT 2019
Powered by FUDForum. Page generated in 0.02296 seconds
