Home » Eclipse Projects » Sirius » Document generation from Sirius And UML Model
Document generation from Sirius And UML Model [message #1751531] Wed, 11 January 2017 08:52 Go to next message
Sébastien GUISSE is currently offline Sébastien GUISSEFriend
Hello, I would like to know if it's possible to generate word (docx) or (odt) document from sirius model And from UML designer model.
If yes where could i find some sample ?
The goal is to generate technical documentation with :
    - text
    - image of models
    - Attribute tables with comments
Thanks a lot
Seb.
Re: Document generation from Sirius And UML Model [message #1751533 is a reply to message #1751531] Wed, 11 January 2017 09:15 Go to previous messageGo to next message
Cedric Brun is currently offline Cedric BrunFriend
Hi Seb,
Indeed it is possible, we are developping the project M2Doc[1] to adress this need for .docx. It alrready provides an integration with Sirius so that you can integrate diagrams directly in the document and fairly sophisticated features for tables. It is reusing AQL as a query language so any user of Sirius should feel at home.
It has not reached a 1.0 level (we plan to bring it there during 2017) but it has been successfully deployed for several customers already. The user documentation is available [2] but feel free to ask any question using a github issue on the project as some steps might not be covered yet.
Feedback would be greatly appreciated.
[1] https://github.com/ObeoNetwork/M2Doc
[2] https://github.com/ObeoNetwork/M2Doc/blob/master/doc/doc/M2DocUserGuide.pdf
http://cedric.brun.io news and articles on eclipse and eclipse modeling.
Re: Document generation from Sirius And UML Model [message #1751536 is a reply to message #1751533] Wed, 11 January 2017 09:58 Go to previous messageGo to next message
Hi Cédric,
Thanks a lot for your quick response.
Sirius is really a great tool !! Very Happy
I use it to modelize :
- database
  • custom Reverse database
  • fields controls with table views (constraints, size, mandatory, ...)
  • Index visualisation
  • Foreign key check
- Services
  • Generate all levels in one step from entity : BO, DAO, DTOIn, DTOOut, Mapper, ...
- Screens
  • Scketchup screens, dialog, Panel, ...
Document génération is what it missed for me
I will give you my feed back on this tool
Seb.
Re: Document generation from Sirius And UML Model [message #1751703 is a reply to message #1751536] Thu, 12 January 2017 16:44 Go to previous messageGo to next message
Thanks so much for your feedback and taking a moment for describing your use case.
Feel free to ask us to add it to the gallery if you want to share it with the community
https://www.eclipse.org/sirius/gallery.html
Re: Document generation from Sirius And UML Model [message #1751704 is a reply to message #1751536] Thu, 12 January 2017 16:44 Go to previous messageGo to next message
Re: Document generation from Sirius And UML Model [message #1795782 is a reply to message #1751704] Fri, 28 September 2018 13:59 Go to previous message
pxDoc Team is currently offline pxDoc TeamFriend
You can also use pxDoc and its integration with Sirius.
pxDoc is a new way of generating documents with a dedicated language (only ~30 keywords) integrated with the Java world. Since pxDoc works on the Java level directly, you can take any Java object as input for your generation.
So you can obviously mix EMF and UML (and any other data that can be accessed with java) to generate your documentations...
You can have a look at the pxDoc documentation, and the pxDoc-Sirius Integration.
Note that you will need to install Xtext and pxDoc before installing the pxDoc-Sirius integration.
Have fun with pxDoc !
Kind regards,
the pxDoc Team
Previous Topic:Document Generation from EMF models
Next Topic:.aird can not be loaded
Current Time: Sun Mar 07 21:51:27 GMT 2021
Powered by FUDForum. Page generated in 0.02104 seconds
