Birt upgrade 2.5.2 > 4.5.0, reports no longer work [message #1751480] |
Tue, 10 January 2017 16:27 |
John Zz Messages: 1 Registered: January 2017 |
After an upgrade from 2.5.2. to 4.5.0, I found many of the rptdesign files on our environment do not work.
The main culprit revolves around this :
org.eclipse.birt.report.engine.api.EngineException: A BIRT exception occurred. See next exception for more information.
ReferenceError: "Double" is not defined.
// problem line
<expression name="expression" type="javascript">"$ " + (Double.parseDouble(dataSetRow["theRowName"]) * -1)</expression>
In the report it is doing a Double.parseDouble (java style) which is not imported out of the box anymore.
If I change this to a java.lang.Double.parseDouble , it works fine. I understand why this may have been removed, it could also be that we manually added it somehow on the 2.5.2 build, it was just so long ago and I wasn't involved.
I am in control of everything but the individual rptdesign files. I'd like them to be backwards compatible. Is there a way for me to import a set of java classes via Rhino (I'm assuming) that would not involve changing the rpt design files?
FUDForum. Page generated in 0.02813 seconds
