Home » Eclipse Projects » Eclipse Platform » Which Adapters available?
Which Adapters available? [message #331209] Thu, 28 August 2008 06:41 Go to next message
Hi there,
as I understand a common pattern used in Eclipse is the "Extensible
Objects" pattern: you can extend an existing class by adding adapters to it.
How can I find out what adapters are available for a certain class? To
find out what to do with a class, I usually look at the class API.
Obviously that's not enough to find out about its adapters, because the
meaning of adapters is to define them outside of the class. So how to
know where to look? And how to know if it's a good idea to use a certain
adapter as it might bring in new dependencies to those outside projects
where the adapter is defined...
Hauke
Re: Which Adapters available? [message #331213 is a reply to message #331209] Thu, 28 August 2008 09:15 Go to previous messageGo to next message
--------------060103040709030506080400
Hauke,
I don't think you really can. The whole point of an adapter is to
provide something not provided by the base implementation. I suppose
the closest that comes to what you want is the registrations for the
|org.eclipse.core.runtime.adapters extension point.|
< http://www.eclipse.org/articles/article.php?file=Article-Ada pters/index.html>
And yes, if you use some other API, you'll depend on (or at least load)
the plugins that provide it.
Hauke Fuhrmann wrote:
> Hi there,
> Cheers,
> Hauke
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Hauke,<br>
<br>
I don't think you really can.&nbsp; The whole point of an adapter is to
provide something not provided by the base implementation.&nbsp; I suppose
the closest that comes to what you want is the registrations for the <code>org.eclipse.core.runtime.adapters
extension point.</code><a
href=" http://www.eclipse.org/articles/article.php?file=Article-Ada pters/index.html"><br>
</a>
<blockquote><a
href=" http://www.eclipse.org/articles/article.php?file=Article-Ada pters/index.html"> http://www.eclipse.org/articles/article.php?file=Article-Ada pters/index.html</a><br>
</blockquote>
the plugins that provide it.<br>
<br>
<br>
<blockquote cite="mid:g95vc2$gbi$1@build.eclipse.org" type="cite">
<pre wrap="">Hi there,
Hauke
</pre>
</blockquote>
</body>
</html>
--------------060103040709030506080400--
Re: Which Adapters available? [message #331253 is a reply to message #331209] Thu, 28 August 2008 11:09 Go to previous message
There is some API in org.eclipse.core.runtime.IAdapterManager to query
adapters without actually loading the adapter targets. Some of the
methods take the object instance in question (as an Object) and a string
for the adapter target (so you don't have to load the class).
Do you have the object to be adapted already?
PW
Paul Webster
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/workbench.htm
Previous Topic:Menu item visibleWhen a handler is active
Next Topic:InfoCenter Exception
Current Time: Mon Mar 17 11:21:00 EDT 2025
Powered by FUDForum. Page generated in 0.25206 seconds
