Re: Oxygen editor missing underscore [message #1751282 is a reply to message #1751268] |
Sat, 07 January 2017 00:10 |
Jonah Graham Messages: 416 Registered: June 2014 |
Quote:This is a duplicate because I cannot find my original post.
Your original one is here: https://www.eclipse.org/forums/index.php/m/1749360/#msg_1749360 but we can continue here. You can find the messages you posted by clicking on your user name and then clicking on all posts, your direct link to all messages is here: https://www.eclipse.org/forums/index.php/sp/201632/
Quote:I have been told to submit a bug report which I did.
Thank you! I haven't managed to find the bug in bugzilla, could you kindly share the bug number here. However in my searches I decided to include resolved bugs and I found https://bugs.eclipse.org/bugs/show_bug.cgi?id=506885 and https://bugs.eclipse.org/bugs/show_bug.cgi?id=498384 which both indicate that the problem is with the font and not Eclipse (they were marked invalid). Comment #4 indicated that resetting the font works: https://bugs.eclipse.org/bugs/show_bug.cgi?id=506885#c4
Quote:I have been told that Oxygen is not officially released until June 2017. (?)
That is correct, Oxygen (aka Eclipse 4.7 including CDT 9.3) is the current, fairly stable, but unreleased version of Eclipse. I, and I am sure the rest of the community, really appreciate the early adopters who live on the bleeding edge. However if you need to downgrade, I recommend using the Neon (aka Eclipse 4.6.2 with CDT 9.2), which is the latest released version of Eclipse. Let me know if you need help finding exactly what you need.
If you have been confused by the names of releases, you are not alone: https://kichwacoders.com/2016/04/28/why-its-time-to-kill-the-eclipse-release-namesneon-oxygen-etc/
Re: Oxygen editor missing underscore [message #1751289 is a reply to message #1751282] |
Sat, 07 January 2017 00:53 |
Anne Creek Messages: 275 Registered: September 2014 |
Thanks for reply.
I guess I'll submit another bug report, no problem.
Apparently the bug report did not indicate the underscore issue.
Since this is my first exposure to Eclipse I was not really sure when I had a bug or just user error. I still have difficulty adding new code to compiled working code and little concerned how it is all going to pan out when I do real debugging.
In the meantime I'll "down shift".
Addendum
I did attempt to post bug report , but I am getting "anonymous cannot post tasks" in red . After I fill out next dialog the red error message goes black, I can pus Send but get no response.
I do not know if the bug was posted , but I got screen shot of major part of it on file.
So it looks as Oxygen bug report is also buggy.
[Updated on: Sat, 07 January 2017 01:17] Report message to a moderator
Re: Oxygen editor missing underscore [message #1751323 is a reply to message #1751310] |
Sun, 08 January 2017 17:17 |
Addendum:
I have implemented this hack to go from Oxygen to Neon:
Copy Oxgen default " workspace" directory . I have renamed it "workspace _NEON"
In Eclipse - Neon switch from original " workspace" to "workspace_NEON".
That restarts new instance of Ecipse_NEON than required project can be selected.
Clumsy , but it works.
[Updated on: Sun, 08 January 2017 17:18] Report message to a moderator
FUDForum. Page generated in 0.03436 seconds
