Home » Newcomers » Newcomers » debug confused
debug confused [message #1751173] Thu, 05 January 2017 11:00 Go to next message
Bianca Bromonti is currently offline Bianca BromontiFriend
I have created a new class, I would like to debug it, but it debugs the previous class I have debugged.
Re: debug confused [message #1751201 is a reply to message #1751173] Thu, 05 January 2017 15:30 Go to previous messageGo to next message
Debugging creates a launcher, you can have multiple of them. Look at the drop-down next to the debug toolbar button; that will tell you wan it is you're launching. You can also right click on a class to bring up the context menu and from there.
Ed Merks
Re: debug confused [message #1751205 is a reply to message #1751173] Thu, 05 January 2017 16:01 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Do the old and new classes have similarities, like the exact same name? Are they in different projects?
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: debug confused [message #1751669 is a reply to message #1751201] Thu, 12 January 2017 11:28 Go to previous messageGo to next message
I wrote this small class in a different version of eclipse (indigo) and I could debug it without problems.
I have imported the project into a new eclipse (mars.2) and I can debug every other classes except this.
In the debug configurations this class doesn't appear in the main class list.
Re: debug confused [message #1751670 is a reply to message #1751205] Thu, 12 January 2017 11:30 Go to previous messageGo to next message
They are in the same project with different names.
Re: debug confused [message #1751673 is a reply to message #1751670] Thu, 12 January 2017 11:52 Go to previous messageGo to next message
Does the class have a "public static void main(String[] args)" method? Don't expect us to be psychic...
Ed Merks
Re: debug confused [message #1751698 is a reply to message #1751673] Thu, 12 January 2017 16:05 Go to previous messageGo to next message
Yes, it has.
Re: debug confused [message #1751700 is a reply to message #1751698] Thu, 12 January 2017 16:22 Go to previous messageGo to next message
As I mentioned, we're not psychic. We know nothing of your file structure or the contents of the file, but we should guess what might be wrong, with the minimal input from you.
In a *.java file that's on the project's classpath and with a proper main method, the context menu's Run As/Debug As submenu will include Java Application. Is that present? If you invoke it, you say it runs/debugs something else?
Note that a response from you that provides no additional elaboration of the details will not prompt another response from me.
Ed Merks
Re: debug confused [message #1751705 is a reply to message #1751700] Thu, 12 January 2017 16:57 Go to previous messageGo to next message
The structure is very simple, and the Run As/Debug As submenu doesn't include this Java Application.
..imports...
public class TraspasoSAP
..variables....
public void TraspasoSAP(){};
public static void conectarBBDD() throws UnknownHostException{}
public static void traspasar(int p_productid) throws JCoException, SQLException, AddressException, MessagingException {}
public static void main(int args) throws JCoException, SQLException, UnknownHostException, AddressException, MessagingException
TraspasoSAP traspaso = new TraspasoSAP();
conectarBBDD();
traspasar(args);
Re: debug confused [message #1751777 is a reply to message #1751705] Fri, 13 January 2017 17:57 Go to previous message
Eric Rizzo is currently offline Eric RizzoFriend
You have the incorrect signature for the main method; it needs to accept String[] as the argument type. Like this:
Previous Topic:Empty "Project Selection"
Next Topic:Where To Start?
Current Time: Sun May 16 19:41:29 GMT 2021
Powered by FUDForum. Page generated in 0.03931 seconds
