ClassNotFoundException: javafx.embed.swt.FXCanvas cannot be found by org.eclipse.gef4.mvc.fx.ui [message #1751020] |
Tue, 03 January 2017 17:10 |
Thomas Johnsson Messages: 10 Registered: June 2010 |
Junior Member |
I had my profiling gef4/Zest based plugin running correctly, starting eclipse from eclipse, using vmarg -Dosgi.framework.extensions=org.eclipse.fx.osgi , and plugins org.eclipse.fx.javafx and org.eclipse.fx.osgi.
However, I also had a warning in the log file:
"WARNING: You are binding against the deprecated org.eclipse.fx.javafx - please remove all javafx imports"
So I try to be a good boy and follow the advice in:
https://www.eclipse.org/forums/index.php/t/1072815/
i.e., using vmarg -Dorg.osgi.framework.bundle.parent=ext instead, and removing org.eclipse.fx.javafx and org.eclipse.fx.osgi from required plugins, and remove javafx.* from imported packages.
However, I now get the following exception when opening the profiler perspective which opens a (subclass of) ZestFxUiView:
java.lang.ClassNotFoundException: javafx.embed.swt.FXCanvas cannot be found by org.eclipse.gef4.mvc.fx.ui_1.0.1.201609060946
The whole horrendous stack trace is included below.
I notice that FXCanvas is in jre/lib/jfxswt.jar, but it is not a bundle. I'm currently using java-1.8.0-oracle-1.8.0.111.x86_64 (linux).
Help please
Thanks is advance
Thomas
!ENTRY org.eclipse.ui 4 4 2017-01-03 16:56:31.720
!MESSAGE Unable to create part
!SUBENTRY 1 org.eclipse.ui 4 1 2017-01-03 16:56:31.721
!MESSAGE Plug-in "com.yepp.cromo.eclipsedev.mylang.profiler" was unable to instantiate class "com.cromosystems.mylang.profiler.perspective.MylangProfilerView".
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "com.yepp.cromo.eclipsedev.mylang.profiler" was unable to instantiate class "com.cromosystems.mylang.profiler.perspective.MylangProfilerView".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:188)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.registry.ViewDescriptor.createView(ViewDescriptor.java:58)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:101)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:278)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:316)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:536)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:520)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:70)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1317)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:72)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:5406)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:173)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:108)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:669)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:70)
at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:142)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:665)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:82)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:135)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
at org.eclipse.ui.internal.WorkbenchPage.setPerspective(WorkbenchPage.java:4091)
at org.eclipse.ui.internal.Workbench.showPerspective(Workbench.java:3096)
at org.eclipse.ui.internal.Workbench.showPerspective(Workbench.java:3041)
at com.yepp.cromo.sessionserver.SessionServerPlugin$5.run(SessionServerPlugin.java:412)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:182)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4528)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4146)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:687)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:604)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Caused by: java.lang.NoClassDefFoundError: javafx/embed/swt/FXCanvas
at org.eclipse.gef4.mvc.fx.ui.MvcFxUiModule.bindFXCanvasFactory(MvcFxUiModule.java:46)
at org.eclipse.gef4.mvc.fx.ui.MvcFxUiModule.configure(MvcFxUiModule.java:90)
at com.google.inject.AbstractModule.configure(AbstractModule.java:59)
at com.google.inject.spi.Elements$RecordingBinder.install(Elements.java:223)
at com.google.inject.spi.Elements.getElements(Elements.java:101)
at com.google.inject.spi.Elements.getElements(Elements.java:92)
at com.google.inject.util.Modules$RealOverriddenModuleBuilder$1.configure(Modules.java:172)
at com.google.inject.internal.InjectorShell$Builder.build(InjectorShell.java:133)
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:103)
at com.google.inject.Guice.createInjector(Guice.java:95)
at com.google.inject.Guice.createInjector(Guice.java:72)
at com.google.inject.Guice.createInjector(Guice.java:62)
at com.cromosystems.mylang.profiler.perspective.MylangProfilerView.<init>(MylangProfilerView.java:102)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
at java.lang.Class.newInstance(Class.java:442)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
... 129 more
Caused by: java.lang.ClassNotFoundException: javafx.embed.swt.FXCanvas cannot be found by org.eclipse.gef4.mvc.fx.ui_1.0.1.201609060946
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
... 151 more
!SUBENTRY 2 org.eclipse.equinox.registry 4 1 2017-01-03 16:56:31.723
!STACK 0
... 151 more
[Updated on: Tue, 03 January 2017 17:13] Report message to a moderator
Re: ClassNotFoundException: javafx.embed.swt.FXCanvas cannot be found by org.eclipse.gef4.mvc.fx.ui [message #1751088 is a reply to message #1751070] |
Wed, 04 January 2017 11:56 |
Hi Thomas,
the warning you are getting is an e(fx)clipse warning that asks you to remove the JavaFX package imports, which are no longer needed with java 8. Additionally, you should be able to remove org.eclipse.fx.javafx from your target. However, e(fx)clipse is still needed with Java 8 in order to bring the JavaFX/SWT integration onto the classpath. With Java 7, e(fx)clipse was needed to bring all of JavaFX onto the classpath. Using -Dosgi.framework.extensions=org.eclipse.fx.osgi is the way to go.
Matthias
FUDForum. Page generated in 0.02582 seconds
