Home » Modeling » TMF (Xtext) » in-editor error message on the wrong cross-reference
in-editor error message on the wrong cross-reference [message #1750955] Mon, 02 January 2017 19:36 Go to next message
Eric Salemi is currently offline Eric SalemiFriend
Member
Below the grammar I use:
grammar com.septentrio.infrastructure.flax.Flax with org.eclipse.xtext.common.Terminals
generate language "http://www.septentrio.com/infrastructure/flax/Flax"
Flax:
    ('package' name=QualifiedName)?
    (imports+=Import)*
    (entities+=Entity)*;
Import:
    'import' importedNamespace=QualifiedNameWithWildcard;
QualifiedName:
    ID ('.' ID)*;
QualifiedNameWithWildcard:
    QualifiedName '.*'?;
Entity:
    Tag|Class;
Tag:
    'tag' name=ID
    ( '{' properties+=TagProperty* '}' )?;
TagProperty:
    name=ID;
Class:
    tagrefs+=TagReference*
	'class' name=ID
	( 'extends' (parents+=[Class|QualifiedName]','?)+ )?
	( '{' sections+=Section* '}' )?;
TagReference:
    '@' tag=[Tag]
    ( '(' ( arguments+=[TagProperty|QualifiedName] ','? )* ')' )?;
Section:
    PropertySection|MethodSection;
PropertySection:
    'properties' '{' properties+=Property* '}';
MethodSection:
    'methods' '{' methods+=Method* '}';
Member:
    Property|Method;
Property:
	type=ElementType name=ID;
Method:
    type=ElementType? name=ID
    ( '(' (parameters+=Parameter','?)* ')' )?
    body=Block;
Block:
    '{' (expressions+=Expression)* '}';
ElementType:
	BasicType|ClassType;
BasicType:
	type=('void'|'any'|'enum'|'logical'|'string'|'integer'|'float');
ClassType:
	type=[Class|QualifiedName];
Parameter:
Symbol:
    Entity|Parameter|Member;
Expression:
    Primary ( {Selection.operand=current} levels+=SelectionLevel )*;
Primary returns Expression:
    '(' Expression ')' |
    {Boolean} value=('true'|'false') |
    {Integer} value=INT |
    {SymbolReference} symbol=[Symbol] => Parameters? |
    {Metadata} '?' name=ID;
SelectionLevel returns Expression:
    {MemberSelection} '.' name=[Member] => Parameters?;
fragment Parameters:
    parameterized ?= '(' (parameters+=Expression','?)* ')';
and I have this validation check:
@Check
def duplicateArgument(TagReference t) {
	val visited = <TagProperty>newArrayList
	for (argument: t.arguments)
		if (visited.contains(argument))
			error(
					'''Duplicate argument "«argument.name»" for tag "«t.tag.name»" for class "«t.getContainerOfType(Class).name»"''',
					LanguagePackage.Literals.TAG_REFERENCE__ARGUMENTS,
					DUPLICATE_ELEMENT
		else
			visited.add(argument)
If I give this to the resulting editor plugin:
tag Animal {
    Running
    Sleeping
@Animal(Running, Sleeping, Sleeping)
class Horse
then the error message is correctly indicating that the "Sleeping" tag argument is duplicate BUT it underlines the "Running" tag argument instead... which is not what I would expect.
As far as I understand, the validation check takes an EObject as input and must report an error on an EStructuralFeature. Since the structure feature of the form "argument+=...", how can I specify which element of the list is in error?
[Updated on: Tue, 03 January 2017 23:13]
Report message to a moderator
Re: in-editor error message on the wrong cross-reference [message #1750956 is a reply to message #1750955] Mon, 02 January 2017 19:46 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
there are tons of methods with different signatures to report the error
e.g. one that takes an index as well e.g.
@Check
var index = 0;
for (argument: t.arguments) {
error(
'''Duplicate argument "«argument.name»" for tag "«t.tag.name»" for class "«EcoreUtil2.getContainerOfType(t,Class).name»"''',
MyDslPackage.Literals.TAG_REFERENCE__ARGUMENTS,
index,
"ERROR_CODE"
else
index+=1
Twitter : @chrdietrich
Re: in-editor error message on the wrong cross-reference [message #1750960 is a reply to message #1750956] Mon, 02 January 2017 23:07 Go to previous message
Member
I missed those for some reason... it is exactly what I need.
I also discovered that the ValidationTestHelper.assertError() method had a form with offset and length to write the corresponding test.
For the record, I wrote the test like this:
@Test
def void testDuplicateClassTagReferenceArgument() {
	tag Tool {
		Powered
		Colored
	@Tool(Colored, Powered, Powered)
	class Lamp
		parse
		.assertError(
				LanguagePackage.Literals.TAG_REFERENCE,
				FlaxValidator.DUPLICATE_ELEMENT,
				StringUtils.ordinalIndexOf(it, 'Powered', 2),
				'Powered'.length,
				'Duplicate argument "Powered" for tag "Tool" for class "Lamp"'
[Updated on: Tue, 03 January 2017 23:12]
Previous Topic:Validator for my language
Next Topic:Load Model
Current Time: Wed Sep 27 21:09:11 GMT 2023
Powered by FUDForum. Page generated in 0.02618 seconds
