Home » Eclipse Projects » P2 » Ant build fails at p2.director
Ant build fails at p2.director [message #1750568] Thu, 22 December 2016 17:10 Go to next message
ayman salah is currently offline ayman salahFriend
So due to having to stick with some eclipse version, I had to install plugins manually by copying them into plugins folder.
After doing that everything works fine and my projects are loaded correctly.
I am using eclipse indigo 3.7.0 64 bit with Xtext 2.9.2
When I run Ant to build my solution it fails at p2.director with this message
[java] [p2.director] Missing requirement: Xtext Generator 2.9.2.v201603040440 (org.eclipse.xtext.generator 2.9.2.v201603040440) requires 'bundle org.eclipse.xtext.xtext.generator [2.9.0,3.0.0)' but it could not be found
I don't know much about p2 but I believe that there is some XML file that I should edit or point to some correct repo or something.
I also am getting this in a step before the build fails:
     [java] [p2.mirror] Unable to satisfy dependency from org.eclipse.xtext.xbase.ui 2.9.2.v201603040440 to bundle org.eclipse.xtext.xbase.ide [2.9.0,3.0.0).
     [java] [p2.mirror] Unable to satisfy dependency from org.eclipse.xtext.generator 2.9.2.v201603040440 to bundle org.eclipse.xtext.xtext.generator [2.9.0,3.0.0).
     [java] [p2.mirror] Messages while mirroring artifact descriptors.
Can you please help me out?
Where does p2.mirror look for jars?
Re: Ant build fails at p2.director [message #1750682 is a reply to message #1750568] Sun, 25 December 2016 08:49 Go to previous message
Any help??
Previous Topic:Backup of file ...product-name\jre\bin\java.dll failed.
Next Topic:How to update with p2 directory without the logback error?
Current Time: Thu Oct 01 14:01:56 GMT 2020
Powered by FUDForum. Page generated in 0.02346 seconds
