Home » Eclipse Projects » Eclipse Kapua » setting Kapua with Kura(connecting kura with kapua)
setting Kapua with Kura [message #1750527] Thu, 22 December 2016 08:56 Go to next message
yuval zohar is currently offline yuval zoharFriend
hello, im trying to build the GreenHouse project with Kura and im willing to control it with the Kapua framework. i couldnt find a detailed documentation for developers which explains what parameters required to put within both admin web dashboards in order to communicate both components.
ill appreciate any help for doing so.
thanks,
yuval
Re: setting Kapua with Kura [message #1771362 is a reply to message #1750527] Thu, 24 August 2017 11:18 Go to previous message
Leonardo Gaube is currently offline Leonardo GaubeFriend
Hi yuval zohar,
there is a pending Pull Request (PR) which explains how to connect Kura Gateway (In this case Raspberry Pi with Kura 3.0) locally to Kapua.
It has not been merged yet, but anyway I am sending the link.
This document will be updated, but for now I think it will be OK.
The link is: https://github.com/eclipse/kapua/pull/780/files.
After it will be merged, it will be located under /docs (https://github.com/eclipse/kapua/tree/develop/docs).
Basically you need to create new Account and User in Kapua, because kapua-sys user cannot receive data.
I hope this helps.
Leonardo
Previous Topic:Example configuration to connect Kura gateway
Next Topic:Kura & Kapua connection
Current Time: Sat Apr 04 13:38:21 GMT 2020
Powered by FUDForum. Page generated in 0.01547 seconds
