Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Forms] bi-directional references - new entries are created as root entries
[EMF Forms] bi-directional references - new entries are created as root entries [message #1750283] Mon, 19 December 2016 14:30 Go to next message
Jim 20100 is currently offline Jim 20100Friend
Member
I have a problem with bi-directional references:
I have 2 classes:
Company
Contact
A Company can have multiple contacts.
A Contact has 0..1 company.
I have a specific file structure
- Quote
- Description
- Contacts
- Contact 1
- Contact 2
- Companies
- Company 1
Problem in EMF Forms: Location of new entries
When I edit the contact entry, on the company field, if I click on "Create and link a new Company", the new Company object is created as a new root object.
I absolutely don't want that, the company has to be created in
Quote > Description > Companies
The same when I edit a company, if I click to create a new Contact, it is created at the root level as well. I want to keep my structure.
another problem: I even cannot remove those unwanted Contact and Company root entries.
Jim
Re: [EMF Forms] bi-directional references - new entries are created as root entries [message #1750344 is a reply to message #1750283] Tue, 20 December 2016 08:33 Go to previous message
Eugen Neufeld is currently offline Eugen NeufeldFriend
Hi Jim,
you must provide your own ReferenceService as you can then change the default behavior where new elements are added to.
Take a look at the DefaultReferenceService and the DefaultReferenceServiceFactory.
In short the DefaultReferenceServiceFactory is an OSGi Service which tells EMFForms that there is a ReferenceService and how it behaves. It allows EMFForms to instantiate the ReferenceService when needed.
The DefaultReferenceService is an implementation of the ReferenceService which lets EMF decide where an Element is added to the containment hierarchy.
Eugen
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Eugen Neufeld
Previous Topic:Ecore cross references not working (?)
Next Topic:[EMF Forms] Custom Databinding converters
Current Time: Tue May 26 04:40:18 GMT 2020
Powered by FUDForum. Page generated in 0.01900 seconds
