Re: Return in methods [message #1750114 is a reply to message #1750078] |
Fri, 16 December 2016 09:21 |
Hugo Bruneliere Messages: 674 Registered: July 2009 |
Thanks a lot for using MoDisco components.
The Java Model Discoverer provides a complete Java model out of the input Java code.
However the Java-to-KDM model transformation is not 100% complete (and there is not necessarily an equivalent in the KDM metamodel which is more generic and thus simpler).
You may take a look to the Bugzilla to see if other users already add the same issue (cf. these bugs for instance), or raise a bug if you feel the need for this.
Hugo Bruneliere, PhD
NaoMod team (IMT Atlantique & LS2N-CNRS)
Nantes - France
FUDForum. Page generated in 0.02597 seconds
