Home » Eclipse Projects » OM2M » Router Internal Error when running tutorial application
Router Internal Error when running tutorial application [message #1750076] Thu, 15 December 2016 18:46 Go to next message
Yu-Hao Hsu is currently offline Yu-Hao HsuFriend
I followed the tutorial: Develop oneM2M applications to create application to test REST API. I run the MySensor.java, MyActuator.java and then run the MyManager.java.
To my understanding, MyManager.java will subscribe mysensor/data and send notification to /in-cse/in-name/mymanager.
But when I run MyManager.java, I got the following error message:
[INFO] - org.eclipse.om2m.core.notifier.Notifier
Sending notify request to: /in-cse/in-name/mymanager
Sending notify request...
[INFO] - org.eclipse.om2m.core.router.Router
Received request in Router: RequestPrimitive [operation=5,
from=admin:admin,
content={
"m2m:sgn" : {
"nev" : {
"rep" : {
"rn" : "cin_266403336",
"ty" : 4,
"ri" : "/mn-cse/cin-266403336",
"pi" : "/mn-cse/cnt-81533083",
"ct" : "20161216T022158",
"lt" : "20161216T022158",
"st" : 0,
"cnf" : "application/text",
"cs" : 3,
"con" : "293"
"rss" : 1
"sud" : false,
"sur" : "/mn-cse/mn-name/mysensor/data/managersub"
requestContentType=application/json,
missing ContentType isnull
No Accept parameter set, setting to default: application/xml
Request targeting another CSE, forwarding to Redirector: null
[INFO] - org.eclipse.om2m.core.redirector.Redirector
RemoteCSE found: /in-cse
[ERROR] - org.eclipse.om2m.core.router.Router
Router internal error
at org.eclipse.om2m.core.redirector.Redirector.sendRedirectorRequest(Redirector.java:138)
at org.eclipse.om2m.core.redirector.Redirector.retarget(Redirector.java:84)
at org.eclipse.om2m.core.router.Router.doRequest(Router.java:165)
at org.eclipse.om2m.core.notifier.Notifier.notify(Notifier.java:162)
at org.eclipse.om2m.core.notifier.Notifier$NotificationWorker$1.run(Notifier.java:291)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Response in Router= ResponsePrimitive [responseStatusCode=5000,
content=Router internal error,
to=admin:admin,
from=/mn-cse,
contentType=text/plain,
Can anyone give me the instruction to fix this error?
Thank you.
Re: Router Internal Error when running tutorial application [message #1750242 is a reply to message #1750076] Mon, 19 December 2016 09:22 Go to previous messageGo to next message
Guillaume Garzone is currently offline Guillaume GarzoneFriend
Member
Be sure to pull the latest version of the code (mater branch) and recompile the project. This looks a lot like a bug we encountered recently and we corrected it.
Hope this helps,
Guillaume
Re: Router Internal Error when running tutorial application [message #1750308 is a reply to message #1750242] Mon, 19 December 2016 19:05 Go to previous messageGo to next message
Hi Guillaume Garzone,
Thank you! After I pull the latest version, it works!
But I found that the tutorial code has some error.
In the MyHandler class of MyActuator.java, MyManager.java and MyMonitor.java, when we want to transfer String requestBody to JSONObject,
JSONObject json = new JSONObject(requestBody);
there will have the error message:
A JSONObject text must begin with '{' at 1 [character 2 line 1]
It seems that requestBody is a string with XML format, so it didn't start form '{', it start from '<'.
So then I change the code so that it can transfer XML format to JSONObject
JSONObject json = XML.toJSONObject(requestBody);
then it can works.
But there is another part seems not make sense. In the MySensor.java, it send sensorValue, which is Integer format, to my sensor/data(container). But in the MyHandler of MyManager.java, tutorial use the following code:
String con = rep.getString("con");
int sensorValue = Integer.parseInt(con);
It use the getString to get the Integer format, I think there may be some error need to be fixed.
Howard
[Updated on: Mon, 19 December 2016 19:06]
Report message to a moderator
Re: Router Internal Error when running tutorial application [message #1750368 is a reply to message #1750308] Tue, 20 December 2016 12:44 Go to previous messageGo to next message
Mahdi Ben Alaya is currently offline Mahdi Ben AlayaFriend
Hello Yu-Hao,
I think getString convert the input to a String value then return it.
The example works in my machine. Did you tried it ?
Re: Router Internal Error when running tutorial application [message #1750602 is a reply to message #1750368] Fri, 23 December 2016 08:27 Go to previous messageGo to next message
hello Mandi,
when I test the original sample code, I get the following error message in the MyHandler of MyManager.java:
org.json.JSONException: JSONObject["con"] not a string.
at org.json.JSONObject.getString(JSONObject.java:721)
at org.eclipse.om2m.app.MyManager$MyHandler.handle(MyManager.java:100)
at com.sun.net.httpserver.Filter$Chain.doFilter(Filter.java:79)
at sun.net.httpserver.AuthFilter.doFilter(AuthFilter.java:83)
at com.sun.net.httpserver.Filter$Chain.doFilter(Filter.java:82)
at sun.net.httpserver.ServerImpl$Exchange$LinkHandler.handle(ServerImpl.java:675)
at sun.net.httpserver.ServerImpl$Exchange.run(ServerImpl.java:647)
Did you know why will be this error message happen?
I try to print out the JSONObject rep, but it looks fine like the following:
rep:{"cs":3,"ct":"20161223T162404","st":0,"con":320,"ty":4,"ri":"/mn-cse/cin-284654618","lt":"20161223T162404","pi":"/mn-cse/cnt-795693924","cnf":"application/text","rn":"cin_284654618"}
Re: Router Internal Error when running tutorial application [message #1750606 is a reply to message #1750602] Fri, 23 December 2016 08:44 Go to previous messageGo to next message
Maybe because your "con" is of type integer and so the code should be updated.
Re: Router Internal Error when running tutorial application [message #1750638 is a reply to message #1750606] Fri, 23 December 2016 14:39 Go to previous messageGo to next message
Mandi,
Yes, I think the problem is just like you said that.
So I replace the code
with the following code:
int sensorValue = rep.getInt("con");
then it works.
Re: Router Internal Error when running tutorial application [message #1750639 is a reply to message #1750638] Fri, 23 December 2016 14:53 Go to previous message
Nice! Feel free to improve the wiki.
Previous Topic:Security in OM2M release1
Next Topic:MN-CSE dynamic IP
Current Time: Mon Mar 08 16:19:18 GMT 2021
Powered by FUDForum. Page generated in 0.01905 seconds
