Home » Eclipse Projects » Papyrus for Real Time » Reuse/extend the UML-RT Capsule Structure Diagram
Reuse/extend the UML-RT Capsule Structure Diagram [message #1749797] Mon, 12 December 2016 12:21 Go to next message
Patrik Nandorf is currently offline Patrik NandorfFriend
I'd like to reuse/extend the UML-RT Capsule Structure Diagram in my custom Viewpoint configuration and add my own palette to it but I'm not sure how to do it.
From what I see the UML-RT Capsule Structure Diagram is defined as a custom viewpoint diagram in the org.eclipse.papyrusrt.umlrt.tooling.diagram.common/configuration/UMLRT.configuration with the ImmplementationID 'UMLRTCapsuleStructure'.
What I've done is to create a Viewpoint ("Dummy Viewpoint") which has the UMLRT.configuration parent (see the attached viewpoint config file below)
The Dummy Viewpoint adds a diagram ("Dummy Structure Diagram") which has the ImpementationID 'UMLRTCapsuleStructure' and the UMLRT.configuration's UML-RT Capsule Structure Diagram as parent.
To the diagram I then add the same rules as the UML-RT Capsule Structure Diagram has in the UMLRT.configuration.
However, when I rightclick a capsule to create my a new Diagram no popup menu is hown in the model explorer and I get:
!ENTRY org.eclipse.ui 4 0 2016-12-12 11:26:24.315
!MESSAGE Unhandled event loop exception
!STACK 0
	at org.eclipse.papyrus.infra.emf.types.rules.container.InvariantContainerRule.canContain(InvariantContainerRule.java:91)
	at org.eclipse.papyrus.infra.emf.types.rules.container.InvariantContainerRule.approveCreationRequest(InvariantContainerRule.java:37)
	at org.eclipse.papyrus.infra.types.rulebased.core.AbstractRule.approveRequest(AbstractRule.java:39)
	at org.eclipse.papyrus.infra.types.rulebased.core.DefaultRuleEditHelperAdvice.processRule(DefaultRuleEditHelperAdvice.java:210)
	at org.eclipse.papyrus.infra.types.rulebased.core.DefaultRuleEditHelperAdvice.processCompositeRule(DefaultRuleEditHelperAdvice.java:187)
	at org.eclipse.papyrus.infra.types.rulebased.core.DefaultRuleEditHelperAdvice.processRule(DefaultRuleEditHelperAdvice.java:205)
	at org.eclipse.papyrus.infra.types.rulebased.core.DefaultRuleEditHelperAdvice.approveRequest(DefaultRuleEditHelperAdvice.java:220)
	at org.eclipse.papyrus.infra.types.rulebased.core.DefaultRuleEditHelperAdvice.approveRequest(DefaultRuleEditHelperAdvice.java:52)
	at org.eclipse.papyrus.infra.types.core.notification.AbstractNotifierEditHelper.approveRequest(AbstractNotifierEditHelper.java:226)
	at org.eclipse.papyrus.infra.types.core.notification.AbstractNotifierEditHelper.getEditCommand(AbstractNotifierEditHelper.java:57)
	at org.eclipse.gmf.runtime.emf.type.core.MetamodelType.getEditCommand(MetamodelType.java:107)
	at org.eclipse.papyrus.infra.services.edit.internal.ElementEditService.getEditCommand(ElementEditService.java:85)
	at org.eclipse.papyrus.infra.newchild.CreationMenuFactory.buildCommand(CreationMenuFactory.java:393)
	at org.eclipse.papyrus.views.modelexplorer.newchild.ModelExplorerMenuFactory.buildCommand(ModelExplorerMenuFactory.java:71)
	at org.eclipse.papyrus.infra.newchild.CreationMenuFactory.constructMenu(CreationMenuFactory.java:204)
	at org.eclipse.papyrus.infra.newchild.CreationMenuFactory.populateMenu(CreationMenuFactory.java:137)
	at org.eclipse.papyrus.views.modelexplorer.newchild.ModelExplorerDynamicNewChild.fill(ModelExplorerDynamicNewChild.java:72)
	at org.eclipse.ui.internal.menus.DynamicMenuContributionItem.fill(DynamicMenuContributionItem.java:147)
	at org.eclipse.jface.action.MenuManager.doItemFill(MenuManager.java:728)
	at org.eclipse.jface.action.MenuManager.update(MenuManager.java:810)
	at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java:472)
	at org.eclipse.jface.action.MenuManager.access$1(MenuManager.java:465)
	at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager.java:497)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:256)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5219)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1340)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1366)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1345)
	at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:198)
	at org.eclipse.swt.widgets.Display.runPopups(Display.java:4595)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4133)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:687)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:604)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
!ENTRY org.eclipse.ui 4 0 2016-12-12 11:26:24.387
!STACK 0
	at org.eclipse.jface.action.MenuManager.update(MenuManager.java:669)
	at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer$8.run(MenuManagerRenderer.java:1202)
	at org.eclipse.swt.widgets.Display.timerProc(Display.java:5144)
	at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
	at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2495)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4141)
The viewpoint configuration file
<configuration:PapyrusConfiguration xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:configuration="http://www.eclipse.org/papyrus/infra/viewpoints/configuration" xmi:id="_utxYkLIcEeanobEfwY7g-w" defaultStakeholder="_FrffsMBOEeaXW62QENb8Aw">
  <stakeholders xmi:id="_FrffsMBOEeaXW62QENb8Aw" name="Dummy Modeler" viewpoints="_FrffscBOEeaXW62QENb8Aw"/>
  <viewpoints xsi:type="configuration:PapyrusViewpoint" xmi:id="_FrffscBOEeaXW62QENb8Aw" name="Dummy Viewpoint">
    <modelKinds xsi:type="configuration:PapyrusDiagram" xmi:id="_FrgGwMBOEeaXW62QENb8Aw" name="Dummy Structure Diagram" icon="platform:/plugin/com.test.ui/icons/icon.png" implementationID="UMLRTCapsuleStructure" categories="_FrijAsBOEeaXW62QENb8Aw" customPalette="platform:/plugin/com.test.ui/models/MyPalette.paletteconfiguration" customStyle="">
      <parent href="platform:/plugin/org.eclipse.papyrusrt.umlrt.tooling.diagram.common/configuration/UMLRT.configuration#_Z79eQHcZEeSnWeKqQOfW2A"/>
       <modelRules xmi:id="_Frgt0MBOEeaXW62QENb8Aw" permit="false">
        <element href="http://www.eclipse.org/uml2/5.0.0/UML#//Package"/>
      </modelRules>
      <modelRules xmi:id="_JYXn0MBTEeaXW62QENb8Aw"/>
      <owningRules xmi:id="_FrhU4MBOEeaXW62QENb8Aw">
        <element href="http://www.eclipse.org/uml2/5.0.0/UML#//Class"/>
      </owningRules>
      <childRules xmi:id="_PD0HsMBTEeaXW62QENb8Aw"/>
      <paletteRules xmi:id="_FrhU4sBOEeaXW62QENb8Aw" permit="false" element="composite.group.*"/>
    </modelKinds>
    <parent href="platform:/plugin/org.eclipse.papyrusrt.umlrt.tooling.diagram.common/configuration/UMLRT.configuration#_3T-cEBP7EeSS0oyATXohNA"/>
  </viewpoints>
  <metamodel href="http://www.eclipse.org/uml2/5.0.0/UML#/"/>
  <categories xmi:id="_FrijAsBOEeaXW62QENb8Aw" name="Dummy Model"/>
</configuration:PapyrusConfiguration>
Re: Reuse/extend the UML-RT Capsule Structure Diagram [message #1749961 is a reply to message #1749797] Wed, 14 December 2016 13:45 Go to previous message
Remi Schnekenburger is currently offline Remi SchnekenburgerFriend
Hi Patrik,
Do you have any issue on startup? Like an exception about an element type model that could not register?
If I look into the InvariantContainerRule class line 91, the element type or its matcher should be null to have a NPE.
Several solutions here
- one of the element types you have declared has issue to load. That is usually because of a wrong id or a configuration file which is not declared or not included in the binary build (never forget the file on the build.properties). There are some junit tests on the Papyrus-RT repository that are looking for such issues => https://git.eclipse.org/c/papyrus-rt/org.eclipse.papyrus-rt.git/tree/tests/junit/umlrt/tooling/org.eclipse.papyrusrt.umlrt.tooling.ui.tests/src/org/eclipse/papyrusrt/umlrt/tooling/ui/tests/configuration/NewChildMenuTest.java or https://git.eclipse.org/c/papyrus-rt/org.eclipse.papyrus-rt.git/tree/tests/junit/umlrt/tooling/org.eclipse.papyrusrt.umlrt.tooling.diagram.statemachine.tests/src/org/eclipse/papyrusrt/umlrt/tooling/diagram/statemachine/editor/tests/RTStateMachineDiagramEditorTests.java
- there is no matcher to your element, which may be a bug in the framework or the declaration of the element. Does the element type congfiguration file validates without any issues?
HTH
Rémi
Remi Schnekenburger
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Previous Topic:RTFactory utility class for Papyrus-RT
Next Topic:Papyrus for Realt Time + Qt GUI + RTOS for full RT application
Current Time: Tue Jan 31 05:07:03 GMT 2023
Powered by FUDForum. Page generated in 0.12055 seconds
