Home » Archived » Eclipse Process Manager (Stardust) » MARS2: Unsupported database type: MSSQL
MARS2: Unsupported database type: MSSQL [message #1749486] Wed, 07 December 2016 10:07 Go to next message
Guan Han Jie is currently offline Guan Han JieFriend
I was following the setup documentation "MSSQL Setup" to switch from Derby database to MSSQL.
However I ran into a problem having the database is not supported.
Did I missed out any of the libraries?
Re: MARS2: Unsupported database type: MSSQL [message #1749560 is a reply to message #1749486] Thu, 08 December 2016 07:01 Go to previous messageGo to next message
Robert Emsbach is currently offline Robert EmsbachFriend
Your DB dialect setting looks correct. The error message could be misleading. Please check your DB connection parameters, add sysconsole parameter -v for verbose output and check/share the log file.
Re: MARS2: Unsupported database type: MSSQL [message #1750468 is a reply to message #1749560] Wed, 21 December 2016 11:04 Go to previous messageGo to next message
chris suen is currently offline chris suenFriend
Hi I got the same error. the following are the log output. Appreciate if anyone have any solution for this issue. thanks
2016-12-08 09:46:05,231 INFO [main] () config.Parameters - CARNOT version: 1.0.1.93
2016-12-08 09:46:05,239 INFO [main] () config.GlobalParameters - Loading properties via provider factory org.eclipse.stardust.common.config.DefaultPropertiesProvider$Factory (priority 1).
2016-12-08 09:46:05,243 INFO [main] () config.DefaultPropertiesProvider - Property bundle carnot.properties bootstrapped from classloader sun.misc.Launcher$AppClassLoader@6bc7c054:
2016-12-08 09:46:05,244 INFO [main] () config.DefaultPropertiesProvider - AuditTrail.Schema =
2016-12-08 09:46:05,244 INFO [main] () config.DefaultPropertiesProvider - AuditTrail.UsePreparedStatements = false
2016-12-08 09:46:05,244 INFO [main] () config.DefaultPropertiesProvider - AuditTrail.DriverClass = org.apache.derby.jdbc.ClientDriver
2016-12-08 09:46:05,244 INFO [main] () config.DefaultPropertiesProvider - Logging.Format = %d{yyyy-MM-dd HH:mm:ss,SSS} %-5p [%t] (%x) %c{2} - %m%n
2016-12-08 09:46:05,244 INFO [main] () config.DefaultPropertiesProvider - Logging.Filters =
2016-12-08 09:46:05,244 INFO [main] () config.DefaultPropertiesProvider - AuditTrail.Type = DERBY
2016-12-08 09:46:05,245 INFO [main] () config.DefaultPropertiesProvider - Logging.Directory = C:\Users\RX\sysconsole/log
2016-12-08 09:46:05,245 INFO [main] () config.DefaultPropertiesProvider - Logging.MaxFileSize = 4194304
2016-12-08 09:46:05,245 INFO [main] () config.DefaultPropertiesProvider - AuditTrail.UseLockTables =
2016-12-08 09:46:05,245 INFO [main] () config.DefaultPropertiesProvider - Secure.Session.Factory =
2016-12-08 09:46:05,245 INFO [main] () config.DefaultPropertiesProvider - License.LicenseFilePath =
2016-12-08 09:46:05,245 INFO [main] () config.DefaultPropertiesProvider - AuditTrail.User = carnot
2016-12-08 09:46:05,245 INFO [main] () config.DefaultPropertiesProvider - Logging.LogLevel = INFO
2016-12-08 09:46:05,245 INFO [main] () config.DefaultPropertiesProvider - Web.ServiceFactory = org.eclipse.stardust.engine.core.runtime.beans.POJOServiceFactory
2016-12-08 09:46:05,245 INFO [main] () config.DefaultPropertiesProvider - GUI.WorklistRotation = true
2016-12-08 09:46:05,245 INFO [main] () config.DefaultPropertiesProvider - Security.DefaultPartition = default
2016-12-08 09:46:05,245 INFO [main] () config.DefaultPropertiesProvider - Client.ServiceFactory = org.eclipse.stardust.engine.core.runtime.beans.POJOServiceFactory
2016-12-08 09:46:05,245 INFO [main] () config.DefaultPropertiesProvider - QueryService.Guarded = true
2016-12-08 09:46:05,246 INFO [main] () config.DefaultPropertiesProvider - Security.DefaultRealm = carnot
2016-12-08 09:46:05,246 INFO [main] () config.DefaultPropertiesProvider - Security.Authentication.ConfigurationName =
2016-12-08 09:46:05,246 INFO [main] () config.DefaultPropertiesProvider - Security.PromptPartition = false
2016-12-08 09:46:05,246 INFO [main] () config.DefaultPropertiesProvider - Dependent.Properties =
2016-12-08 09:46:05,246 INFO [main] () config.DefaultPropertiesProvider - Mail.Host = localhost
2016-12-08 09:46:05,246 INFO [main] () config.DefaultPropertiesProvider - AuditTrail.URL = jdbc:derby://localhost:1527/ipp;create=true
2016-12-08 09:46:05,246 INFO [main] () config.DefaultPropertiesProvider - Security.PromptRealm = false
2016-12-08 09:46:05,246 INFO [main] () config.DefaultPropertiesProvider - Credential.Provider =
2016-12-08 09:46:05,246 INFO [main] () config.DefaultPropertiesProvider - Security.PromptDomain = false
2016-12-08 09:46:05,246 INFO [main] () config.DefaultPropertiesProvider - Model.RepositoryDirectoryPath =
2016-12-08 09:46:05,246 INFO [main] () config.DefaultPropertiesProvider - Mail.Sender = user@localhost
2016-12-08 09:46:05,247 INFO [main] () config.DefaultPropertiesProvider - GUI.WorklistRetrievalInterval = 20
2016-12-08 09:46:05,251 INFO [main] () log.extensions - Initializing static extensions resolver
2016-12-08 09:46:05,252 INFO [main] () log.extensions - Initializing Service Provider extensions resolver
2016-12-08 09:46:05,252 INFO [main] () log.extensions - Using extensions manager: org.eclipse.stardust.engine.core.runtime.beans.PartitionAwareExtensionsManager@27f8302d
2016-12-08 09:46:05,259 INFO [main] () console.ConsoleCommand - Create Infinity schema:
2016-12-08 09:46:05,260 INFO [main] () console.ConsoleCommand - Database type : MSSQL
2016-12-08 09:46:05,260 INFO [main] () console.ConsoleCommand - Database URL : jdbc:sqlserver://127.0.0.1/databaseName=Test
2016-12-08 09:46:05,261 INFO [main] () console.ConsoleCommand - Database user : sa
2016-12-08 09:46:05,261 INFO [main] () console.ConsoleCommand - Database schema : sysSchema
2016-12-08 09:46:05,261 INFO [main] () console.ConsoleCommand - Database driver : com.microsoft.sqlserver.jdbc.SQLServerDriver
2016-12-08 09:46:05,304 INFO [main] () console.ConsoleCommand -
2016-12-08 09:46:06,162 WARN [main] () console.DefaultConsoleProcessor - Operation could not be performed: Unsupported database type: MSSQL
2016-12-08 09:46:06,164 WARN [main] () console.DefaultConsoleProcessor -
org.eclipse.stardust.common.error.InternalException: Unsupported database type: MSSQL
at org.eclipse.stardust.engine.core.persistence.jdbc.DBDescriptor.create(DBDescriptor.java:181)
at org.eclipse.stardust.engine.core.persistence.jdbc.DBDescriptor$1.getValue(DBDescriptor.java:117)
at org.eclipse.stardust.common.config.GlobalParameters.getOrInitialize(GlobalParameters.java:467)
at org.eclipse.stardust.common.config.GlobalParameters.initializeIfAbsent(GlobalParameters.java:437)
at org.eclipse.stardust.engine.core.persistence.jdbc.DBDescriptor.create(DBDescriptor.java:89)
at org.eclipse.stardust.engine.core.persistence.jdbc.Session.<init>(Session.java:215)
at org.eclipse.stardust.engine.core.persistence.jdbc.SessionFactory.createSession(SessionFactory.java:82)
at org.eclipse.stardust.engine.cli.sysconsole.AuditTrailCommand.run(AuditTrailCommand.java:126)
at org.eclipse.stardust.common.utils.console.DefaultConsoleProcessor.execute(DefaultConsoleProcessor.java:128)
at org.eclipse.stardust.engine.cli.sysconsole.Main.run(Main.java:77)
at org.eclipse.stardust.engine.cli.sysconsole.Main.main(Main.java:66)
Re: MARS2: Unsupported database type: MSSQL [message #1750578 is a reply to message #1749560] Thu, 22 December 2016 23:39 Go to previous messageGo to next message
Robert Emsbach wrote on Thu, 08 December 2016 07:01
Hi Robert, sorry for late reply as I have some other matters to attend during the whole month.
After running the script:
C:\Users\RX\sysconsole\bin>sysconsole -v -r com.microsoft.sqlserver.jdbc.SQLServerDriver -dbtype MSSQL -dbschema Test -l jdbc:sqlserver://127.0.0.1/databaseName=Test -d sa -s s@ createschema
Here is the log generated:
2016-12-23 07:36:49,119 INFO  [main] () config.Parameters - CARNOT version: 1.0.1.93
2016-12-23 07:36:49,126 INFO  [main] () config.GlobalParameters - Loading properties via provider factory org.eclipse.stardust.common.config.DefaultPropertiesProvider$Factory (priority 1).
2016-12-23 07:36:49,131 INFO  [main] () config.DefaultPropertiesProvider - Property bundle carnot.properties bootstrapped from classloader sun.misc.Launcher$AppClassLoader@6bc7c054:
2016-12-23 07:36:49,131 INFO  [main] () config.DefaultPropertiesProvider -   AuditTrail.Schema =
2016-12-23 07:36:49,132 INFO  [main] () config.DefaultPropertiesProvider -   AuditTrail.UsePreparedStatements = false
2016-12-23 07:36:49,132 INFO  [main] () config.DefaultPropertiesProvider -   AuditTrail.DriverClass = org.apache.derby.jdbc.ClientDriver
2016-12-23 07:36:49,132 INFO  [main] () config.DefaultPropertiesProvider -   Logging.Format = %d{yyyy-MM-dd HH:mm:ss,SSS} %-5p [%t] (%x) %c{2} - %m%n
2016-12-23 07:36:49,132 INFO  [main] () config.DefaultPropertiesProvider -   Logging.Filters =
2016-12-23 07:36:49,132 INFO  [main] () config.DefaultPropertiesProvider -   AuditTrail.Type = DERBY
2016-12-23 07:36:49,132 INFO  [main] () config.DefaultPropertiesProvider -   Logging.Directory = C:\Users\RX\sysconsole/log
2016-12-23 07:36:49,132 INFO  [main] () config.DefaultPropertiesProvider -   Logging.MaxFileSize = 4194304
2016-12-23 07:36:49,132 INFO  [main] () config.DefaultPropertiesProvider -   AuditTrail.UseLockTables =
2016-12-23 07:36:49,132 INFO  [main] () config.DefaultPropertiesProvider -   Secure.Session.Factory =
2016-12-23 07:36:49,132 INFO  [main] () config.DefaultPropertiesProvider -   License.LicenseFilePath =
2016-12-23 07:36:49,133 INFO  [main] () config.DefaultPropertiesProvider -   AuditTrail.User = carnot
2016-12-23 07:36:49,133 INFO  [main] () config.DefaultPropertiesProvider -   Logging.LogLevel = INFO
2016-12-23 07:36:49,133 INFO  [main] () config.DefaultPropertiesProvider -   Web.ServiceFactory = org.eclipse.stardust.engine.core.runtime.beans.POJOServiceFactory
2016-12-23 07:36:49,133 INFO  [main] () config.DefaultPropertiesProvider -   GUI.WorklistRotation = true
2016-12-23 07:36:49,133 INFO  [main] () config.DefaultPropertiesProvider -   Security.DefaultPartition = default
2016-12-23 07:36:49,133 INFO  [main] () config.DefaultPropertiesProvider -   Client.ServiceFactory = org.eclipse.stardust.engine.core.runtime.beans.POJOServiceFactory
2016-12-23 07:36:49,133 INFO  [main] () config.DefaultPropertiesProvider -   QueryService.Guarded = true
2016-12-23 07:36:49,133 INFO  [main] () config.DefaultPropertiesProvider -   Security.DefaultRealm = carnot
2016-12-23 07:36:49,133 INFO  [main] () config.DefaultPropertiesProvider -   Security.Authentication.ConfigurationName =
2016-12-23 07:36:49,133 INFO  [main] () config.DefaultPropertiesProvider -   Security.PromptPartition = false
2016-12-23 07:36:49,133 INFO  [main] () config.DefaultPropertiesProvider -   Dependent.Properties =
2016-12-23 07:36:49,134 INFO  [main] () config.DefaultPropertiesProvider -   Mail.Host = localhost
2016-12-23 07:36:49,134 INFO  [main] () config.DefaultPropertiesProvider -   AuditTrail.URL = jdbc:derby://localhost:1527/ipp;create=true
2016-12-23 07:36:49,134 INFO  [main] () config.DefaultPropertiesProvider -   Security.PromptRealm = false
2016-12-23 07:36:49,134 INFO  [main] () config.DefaultPropertiesProvider -   Credential.Provider =
2016-12-23 07:36:49,134 INFO  [main] () config.DefaultPropertiesProvider -   Security.PromptDomain = false
2016-12-23 07:36:49,134 INFO  [main] () config.DefaultPropertiesProvider -   Model.RepositoryDirectoryPath =
2016-12-23 07:36:49,134 INFO  [main] () config.DefaultPropertiesProvider -   Mail.Sender = user@localhost
2016-12-23 07:36:49,134 INFO  [main] () config.DefaultPropertiesProvider -   GUI.WorklistRetrievalInterval = 20
2016-12-23 07:36:49,139 INFO  [main] () log.extensions - Initializing static extensions resolver
2016-12-23 07:36:49,140 INFO  [main] () log.extensions - Initializing Service Provider extensions resolver
2016-12-23 07:36:49,140 INFO  [main] () log.extensions - Using extensions manager: org.eclipse.stardust.engine.core.runtime.beans.PartitionAwareExtensionsManager@27f8302d
2016-12-23 07:36:49,147 INFO  [main] () console.ConsoleCommand - Create Infinity schema:
2016-12-23 07:36:49,148 INFO  [main] () console.ConsoleCommand - Database type   : MSSQL
2016-12-23 07:36:49,148 INFO  [main] () console.ConsoleCommand - Database URL    : jdbc:sqlserver://127.0.0.1/databaseName=Test
2016-12-23 07:36:49,149 INFO  [main] () console.ConsoleCommand - Database user   : sa
2016-12-23 07:36:49,149 INFO  [main] () console.ConsoleCommand - Database schema : Test
2016-12-23 07:36:49,149 INFO  [main] () console.ConsoleCommand - Database driver : com.microsoft.sqlserver.jdbc.SQLServerDriver
2016-12-23 07:36:49,197 INFO  [main] () console.ConsoleCommand -
2016-12-23 07:36:50,496 WARN  [main] () console.DefaultConsoleProcessor - Operation could not be performed: Unsupported database type: MSSQL
2016-12-23 07:36:50,497 WARN  [main] () console.DefaultConsoleProcessor -
[Updated on: Thu, 22 December 2016 23:49]
Report message to a moderator
Re: MARS2: Unsupported database type: MSSQL [message #1750596 is a reply to message #1750578] Fri, 23 December 2016 07:40 Go to previous messageGo to next message
I have also tested the db connection with other JDBC client. it is working fine. Suspect something not right when using -dbtype MSSQL.
Re: MARS2: Unsupported database type: MSSQL [message #1750600 is a reply to message #1750596] Fri, 23 December 2016 07:50 Go to previous message
Just another thought, is there any other version of sysconsole other than what is stated in our pom.xml file header below?
<groupId>local</groupId>
<artifactId>sysconsole</artifactId>
<packaging>jar</packaging>
<version>1.0-SNAPSHOT</version>
Previous Topic:Stardust portal-Participant Manager Tab empty
Next Topic:participant manager empty tab
Current Time: Tue Nov 24 19:18:43 GMT 2020
Powered by FUDForum. Page generated in 0.02151 seconds
