Eclipse.exe vanished while writing code [message #1749320] |
Mon, 05 December 2016 13:30 |
Alexander Branchaud Messages: 5 Registered: December 2016 |
As title and description suggests. I was in the middle of writing code last night when eclipse closed itself without any error code. I tried to rerun it and the shortcut was saying the file didn't exist. When I looked at the folder the exe was gone. After some fiddling about trying to get it to work, I decided to delete every eclipse folder I could find and reinstall a fresh copy unfortunately the installer exe also closes itself after selecting any version to install.
Any help would be greatly appreciated.
[Updated on: Tue, 06 December 2016 00:43] Report message to a moderator
Re: Eclipse.exe vanished while writing code [message #1749375 is a reply to message #1749320] |
Tue, 06 December 2016 00:46 |
!SESSION 2016-12-05 18:30:05.958 -----------------------------------------------
eclipse.buildId=4.6.1.M20160907-1200
java.version=1.8.0_111
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
!ENTRY org.eclipse.egit.ui 2 0 2016-12-05 18:30:51.205
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\*********'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
!ENTRY org.eclipse.jface.text 2 0 2016-12-05 18:33:05.813
!MESSAGE Duplicate template id: 'org.eclipse.wst.xslt.templates.xpath.number'
!MESSAGE Duplicate template id: 'org.eclipse.wst.xslt.templates.xpath.round'
!ENTRY org.eclipse.jface.text 2 0 2016-12-05 18:33:05.917
!ENTRY org.eclipse.jface.text 2 0 2016-12-05 18:33:05.918
[Updated on: Tue, 06 December 2016 00:51] Report message to a moderator
FUDForum. Page generated in 0.08346 seconds
