Hello!
I'm receiving the following error while using the mqttv 1.1.0 library.
Caused by: java.util.MissingResourceException: Can't find resource for bundle 'org.eclipse.paho.client.mqttv3.internal.nls.logcat_en_US', key ''
12-02 18:47:34.072: E/AndroidRuntime(22233): at java.util.ResourceBundle.missingResourceException(ResourceBundle.java:238)
12-02 18:47:34.072: E/AndroidRuntime(22233): at java.util.ResourceBundle.getBundle(ResourceBundle.java:230)
12-02 18:47:34.072: E/AndroidRuntime(22233): at java.util.ResourceBundle.getBundle(ResourceBundle.java:139)
12-02 18:47:34.072: E/AndroidRuntime(22233): at org.eclipse.paho.client.mqttv3.logging.LoggerFactory.getLogger(LoggerFactory.java:73)
12-02 18:47:34.072: E/AndroidRuntime(22233): at org.eclipse.paho.client.mqttv3.MqttAsyncClient.<clinit>(MqttAsyncClient.java:87)
12-02 18:47:34.072: E/AndroidRuntime(22233): ... 14 more
As far as I know, there is no resource defined as logcat_en_us.
The full error:
Caused by: java.lang.ExceptionInInitializerError
12-02 18:47:34.072: E/AndroidRuntime(22233): at org.eclipse.paho.android.service.MqttConnection.connect(MqttConnection.java:282)
12-02 18:47:34.072: E/AndroidRuntime(22233): at org.eclipse.paho.android.service.MqttService.connect(MqttService.java:323)
12-02 18:47:34.072: E/AndroidRuntime(22233): at org.eclipse.paho.android.service.MqttAndroidClient.doConnect(MqttAndroidClient.java:462)
12-02 18:47:34.072: E/AndroidRuntime(22233): at org.eclipse.paho.android.service.MqttAndroidClient.access$200(MqttAndroidClient.java:70)
12-02 18:47:34.072: E/AndroidRuntime(22233): at org.eclipse.paho.android.service.MqttAndroidClient$MyServiceConnection.onServiceConnected(MqttAndroidClient.java:109)
12-02 18:47:34.072: E/AndroidRuntime(22233): at android.app.LoadedApk$ServiceDispatcher.doConnected(LoadedApk.java:1335)
12-02 18:47:34.072: E/AndroidRuntime(22233): at android.app.LoadedApk$ServiceDispatcher$RunConnection.run(LoadedApk.java:1352)
12-02 18:47:34.072: E/AndroidRuntime(22233): at android.os.Handler.handleCallback(Handler.java:739)
12-02 18:47:34.072: E/AndroidRuntime(22233): at android.os.Handler.dispatchMessage(Handler.java:95)
12-02 18:47:34.072: E/AndroidRuntime(22233): at android.os.Looper.loop(Looper.java:158)
12-02 18:47:34.072: E/AndroidRuntime(22233): at android.app.ActivityThread.main(ActivityThread.java:7224)
12-02 18:47:34.072: E/AndroidRuntime(22233): at java.lang.reflect.Method.invoke(Native Method)
12-02 18:47:34.072: E/AndroidRuntime(22233): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1230)
12-02 18:47:34.072: E/AndroidRuntime(22233): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1120)
12-02 18:47:34.072: E/AndroidRuntime(22233): Caused by: java.util.MissingResourceException: Can't find resource for bundle 'org.eclipse.paho.client.mqttv3.internal.nls.logcat_en_US', key ''
