Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » emf forms observable updates across threads(modifying emf model observed in two tabs of RAP workbench view)
emf forms observable updates across threads [message #1749187] Fri, 02 December 2016 20:11 Go to next message
Jay Norwood is currently offline Jay NorwoodFriend
I'm seeing a null pointer exception in SetCommand.java:362 in org.eclipse.emf.edit.command.SetCommand.create, if I use the emf forms editor to change an attribute in a model instance that is being viewed in two tabs. This is in a RAP workbench application.
What is interesting is that when using the programming api, the values are updated in both views without the exception.
I see in some descriptions that these TAB views are each in their own UI thread in RAP. Is that correct?
If so, then this error suggests to me that emf forms observable updates need to be delayed until their individual UI is active. That's just my guess. I'll attach the stack unwind at the exception:
  • Attachment: err.txt
    (Size: 5.11KB, Downloaded 115 times)
[Updated on: Fri, 02 December 2016 20:17]
Report message to a moderator
Re: emf forms observable updates across threads [message #1749283 is a reply to message #1749187] Mon, 05 December 2016 08:26 Go to previous messageGo to next message
Eugen Neufeld is currently offline Eugen NeufeldFriend
Hi Jay,
How do you create the input data that you pass to emf forms?
For me it looks like your editingdomain is null.
Eugen
Eugen Neufeld
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: emf forms observable updates across threads [message #1749438 is a reply to message #1749283] Tue, 06 December 2016 18:07 Go to previous messageGo to next message
The model instance is loaded from an xmi file.
dsloaded = (Dsense) resource.getContents().get(0);
The list being displayed is cleared, then repopulated. I've tried repopulating the list both directly via emf api calls, or by executing a command to add a list of new items, such as below:
EditingDomain editingDomain = AdapterFactoryEditingDomain.getEditingDomainFor(cameraRecordings);
Command command = AddCommand.create(editingDomain, cameraRecordings, cameraRecordings.getRecordings(),crn.getRecordings());
editingDomain.getCommandStack().execute(command);
These api accesses seem to work ok to modify the model, and the values are updated in the various views with an error.
I get an error, though, if I try to manually edit the class attributes using the emf forms editing dialogs.
However, if I create a copy of the full model for each tab view, using ECoreUtil.copy, then the emf forms dialog editing works without error.
dsense = EcoreUtil.copy(DemoWorkbench.getDsenseInstance());
So, does EcoreUtil.copy have some side-effect wrt the editing domain that would enable the emf forms operation? I was guessing that the problem was that listeners in the other UI threads (per tab) were being notified by the emf forms databinding while the threads were not active.
I'll attempt to make some small example.
Re: emf forms observable updates across threads [message #1749572 is a reply to message #1749438] Thu, 08 December 2016 09:36 Go to previous messageGo to next message
Hi Jay,
a small example would be great. Could you attach it to a bug report please.
Thank you.
Eugen
Eugen Neufeld
Re: emf forms observable updates across threads [message #1752454 is a reply to message #1749572] Tue, 24 January 2017 03:02 Go to previous message
There is info on this type of emf problem here. A couple of solutions were proposed. One using cdo, the other using transactions all within a display thread.
https://javahacks.net/2016/07/13/emf-thread-safety/
Previous Topic:[EMF Client Platform] Building a standalone product out of EMF CP?
Next Topic:[EDapt] Windows filenames are not URIs
Current Time: Wed Aug 12 08:03:01 GMT 2020
Powered by FUDForum. Page generated in 0.01704 seconds
