Scout Neon & Testing [message #1748922] |
Wed, 30 November 2016 08:24 |
Hi there,
I'm just wondering what your testing strategies are regarding the new Scout HTML framework.
With the drop of OSGI bundles plain unit testing is much easier than ever.
But how are you conducting your UI tests?
How are you testing the state of your UI based on permissions or specific values? Lets say an Admin-Role is able to edit a field whereas for a regular user this field is not visible or at least disabled.
How do you test such cases?
Peter
Re: Scout Neon & Testing [message #1748934 is a reply to message #1748927] |
Wed, 30 November 2016 09:28 |
what do you mean with:
Ivan Motsch wrote on Wed, 30 November 2016 08:55Please check the various testing maven modules in the scout open source repo.
Could you please point me to where I can find this?
Peter
Re: Scout Neon & Testing [message #1748955 is a reply to message #1748934] |
Wed, 30 November 2016 11:58 |
Unfortunately the selenium test suite is not yet available in the open source repo. If you're interested in doing Selenium tests, I could give you a few hints on where to start with Scout and Selenium. We plan to release the test suite as open source, but right now we test against an internal application, so we must first change the tests to work with the Scout widgets app, which is already available on GitHub.
Eclipse Scout Homepage | Documentation | GitHub
FUDForum. Page generated in 0.04478 seconds
