Home » Eclipse Projects » BPMN 2.0 Modeler » Multiple Instances Embedded SubProcess Input Instance Parameter Problem
Multiple Instances Embedded SubProcess Input Instance Parameter Problem [message #1748564] Thu, 24 November 2016 12:28
Robert Georges is currently offline Robert GeorgesFriend
I am trying to design a simple Multiple Instances Embedded SubProcess. It should iterate a given list and pass the list items to the embedded activity.
index.php/fa/27694/0/
The problem is, that the Input Instance Parameter is not available in the dropdown box for the User Tasks I/O Parameter Input Data Mapping.
index.php/fa/27695/0/
Is there something else I need to do?
I am using
BPMN2 Modeler - Diagram Editor 1.3.1.Final-v20160914-1606-B56
with
BPMN2 Modeler - jBPM Runtime Extension Feature 1.3.1.Final-v20160914-1606-B56
Previous Topic:In memory 2 sequence flow created while loading the resource file.
Next Topic:how to set Custom Task default value
Current Time: Sun Oct 01 09:58:44 GMT 2023
Powered by FUDForum. Page generated in 0.01830 seconds
