Home » Eclipse Projects » GEF » [Zest] Suppress multi-selection on the canvas
[Zest] Suppress multi-selection on the canvas [message #1748250] Mon, 21 November 2016 10:30 Go to next message
How do I suppress multi-selection (LMouse+Shift, LMouse/RMouse selection box) on the current canvas (ZestContentViewer)?
Zest 0.2.0 is used.
Re: [Zest] Suppress multi-selection on the canvas [message #1748261 is a reply to message #1748250] Mon, 21 November 2016 10:59 Go to previous messageGo to next message
Hi Christoph,
you can remove the bindings for MarqueeOnDragPolicy by extending ZestFxJFaceModule and overriding the bindMarqueeOnDragPolicyAsIRootPartAdapter() method with an empty implementation.
Matthias
Re: [Zest] Suppress multi-selection on the canvas [message #1748446 is a reply to message #1748250] Wed, 23 November 2016 04:24 Go to previous messageGo to next message
Thanks for your reply!
I am guessing that the behavior has been changed since release 0.2.0.
A class named ZestFxJFaceModule is not available but one named ZestFxModule.
ZestFxModule extends MvcFxModule which contains the following method:
	 * Adds a binding for {@link FXMarqueeOnDragPolicy} to the
	 * {@link AdapterMap} binder for {@link FXRootPart}.
	 * @param adapterMapBinder
	 *            The {@link MapBinder} to be used for the binding registration.
	 *            In this case, will be obtained from
	 *            {@link AdapterMaps#getAdapterMapBinder(Binder, Class)} using
	 *            {@link FXRootPart} as a key.
	 * @see AdapterMaps#getAdapterMapBinder(Binder, Class)
	protected void bindOnDragPoliciesAsFXRootPartAdapters(
			MapBinder<AdapterKey<?>, Object> adapterMapBinder) {
		adapterMapBinder.addBinding(
				AdapterKey.get(FXClickDragTool.DRAG_TOOL_POLICY_KEY)).to(
				FXMarqueeOnDragPolicy.class);
I've overritten ZestFxModule and named the new class MyZestFxModule with an empty method.
	protected void bindOnDragPoliciesAsFXRootPartAdapters(MapBinder<AdapterKey<?>, Object> adapterMapBinder) {
		// super.bindOnDragPoliciesAsFXRootPartAdapters(adapterMapBinder);
Further I've bound MyZestFxUIModule to MyZestContentViewer class by overwriting the createModule method.
	protected Module createModule() {
		if (PlatformUI.isWorkbenchRunning()) {
			return Modules.override(new ZestFxUiModule()).with(new MyZestFxModule());
		} else {
			return new MyZestFxModule();
Sadly, that did not solve the multi selection and the marquee (Did not know the term) can still be used.
Re: [Zest] Suppress multi-selection on the canvas [message #1748476 is a reply to message #1748446] Wed, 23 November 2016 08:26 Go to previous messageGo to next message
Hi Christoph,
yes you are right the names changed. Your approach seems to be correct, though. The marquee selection definitely cannot be used anymore if the binding for FXMarqueeOnDragPolicy is missing from the module. I would suggest looking at the references to FXMaruqeeOnDragPolicy within your workspace to find any direct use of the policy. Moreover, you can use the injector to create an instance of FXRootPart and take a look at the injected adapters to ensure that the policy is not present.
However, I overlooked the first part of your question regarding appending selections. This can be done by subclassing FXFocusAndSelectOnClickPolicy (and adjusting the bindings within the module accordingly), where the selection change is computed. Unfortunately, in the 0.2.0 version, there is no method isAppend(MouseEvent) present, therefore, you have to copy and adjust the code.
Matthias
[Updated on: Wed, 23 November 2016 08:31] by Moderator
Re: [Zest] Suppress multi-selection on the canvas [message #1748482 is a reply to message #1748476] Wed, 23 November 2016 09:03 Go to previous message
Thank you Matthias, that worked.
For reason of your response I could easily figure out the issuing behavior and fixed it.
Thanks for all the help!
Both of you guys provide a protruding support!
Previous Topic:[Zest]
Next Topic:How to avoid Node overlapping in horizontal tree layout algorithm in zest
Current Time: Mon May 12 04:50:40 EDT 2025
Powered by FUDForum. Page generated in 0.04067 seconds
