Re: Share custom palettes [message #1748077 is a reply to message #1748068] |
Fri, 18 November 2016 10:57 |
hi,
In which version did your works ?
A way to customize palette is to create a new PaletteConfiguration model. After you can use it through an extension point. I don't know exactly how to do it with viewpoint, sorry.
In oxygen, when you create a new palette configuration model with Palette > Right click > customize: this tool now create palette configuration model with associated element type model. There is a button to export it to workspace.
The use of palette.xml is deprecated.
HTH
Mickaël
Re: Share custom palettes [message #1748097 is a reply to message #1748096] |
Fri, 18 November 2016 13:06 |
no, there is some changes at the element type metamodel. References between specialized type are now href and not done with a string id. You can try it to have an idea of the structure but it will not be compliant with 2.0
FUDForum. Page generated in 0.02536 seconds
