Home » Modeling » Graphiti » Vertical alignment
Vertical alignment [message #1747594] Wed, 16 November 2016 11:32 Go to next message
Kristine Jetzke is currently offline Kristine JetzkeFriend
I'm trying to set the vertical alignment of a text to top but I cannot get it to work, the text stays in the center.
I used the filesystem example code and changed
text.setVerticalAlignment(Orientation.ALIGNMENT_CENTER);
to
text.setVerticalAlignment(Orientation.ALIGNMENT_TOP);
in
org.eclipse.graphiti.examples.filesystem.patterns.FilePattern.doAdd(IAddContext)
to no effect.
Any suggestions on what else I need to change to get it working?
Kristine
Re: Vertical alignment [message #1747997 is a reply to message #1747594] Thu, 17 November 2016 14:27 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
Kristine,
that appears to be a bug in Graphiti. Would you please file this as a Bugzilla against Graphiti?
Michael
Re: Vertical alignment [message #1748105 is a reply to message #1747997] Fri, 18 November 2016 14:02 Go to previous message
Thanks, I created https://bugs.eclipse.org/bugs/show_bug.cgi?id=507729
Previous Topic:Update diagram when drag and drop
Next Topic:Bring Connection shape to front (z-index)
Current Time: Sun Jan 17 13:56:29 GMT 2021
Powered by FUDForum. Page generated in 0.02027 seconds
