Re: OOmph offline installation failing [message #1747328 is a reply to message #1747297] |
Sat, 12 November 2016 09:00 |
Ed Merks Messages: 33140 Registered: July 2009 |
Well, I could start listing places that I think might be an issue, but in the end, I wonder what the overall goal here is? There's ~/.eclipse/org.eclipse.oomph.p2/cache where Oomph caches the things that p2 itself doesn't always cache so well. There's p2's own cache, but that's in the agent which you probably copied with the pool, I guess. There's the ~/.eclipse/org.eclipse.oomph.setup/cache where setup files are cached. But you suggest you've copied these. I assume you've selected the Offline check mark.
But what's the goal? Yes, I understand of course you want something to work offline, but why not just create an installation and copy it to the offline machine? I.e., there must be flexibility you're trying to achieve, that likely would be far better achieved if you created mirrors of the update sites and use those mirrors so that the full flexibility of being able to install anything would be possible...
Ed Merks
FUDForum. Page generated in 0.03877 seconds
