Home » Eclipse Projects » NatTable » Groupby display name shows original name(Groupby columns shows original column name, not the renamed column name)
Groupby display name shows original name [message #1747250] Fri, 11 November 2016 09:31 Go to next message
Naveen Sabapathy is currently offline Naveen SabapathyFriend
Member
Refer the example, "Tutorial Example -> Integration -> SortableGroupByFilterColumnGroupAndFreezeExample"
the column name of "Firstname" has been changed to "ghghhg". But after doing the group by its showing the actual name "Firstname", not the new name.
Re: Groupby display name shows original name [message #1747255 is a reply to message #1747250] Fri, 11 November 2016 10:24 Go to previous message
Dirk Fauth is currently offline Dirk FauthFriend
File a bug that GroupBy is not connected to the ColumnHeader rename feature. Need to check if we are able to fix that somehow.
Previous Topic:Facing issue while rename column header in Nattable
Next Topic:Problem with greyed out columns when table is resized
Current Time: Thu Feb 20 21:50:44 GMT 2020
Powered by FUDForum. Page generated in 0.04247 seconds
