Home » Eclipse Projects » Paho » How to publish only one message using a Java MQTT client using Eclipse Paho(MqttAndroidClient paho.mqtt.java.pahoandroidsample)
How to publish only one message using a Java MQTT client using Eclipse Paho [message #1746826] |
Sat, 05 November 2016 08:58 |
Javier Sanchez Messages: 3 Registered: November 2016 |
I'm doing a project for my final University work. I want do a android app that comunicates with my raspberry pi using MQTT protocol. To do it I'm using a mosquitto broker, but when I publish message in a broker using the Java MQTT client using Eclipse Paho, my app publish the same message 5 times, and I don't know if the fault is of my class that publish message, or of my class on_create() of android.
My code is the following:
public class MainActivity extends AppCompatActivity implements View.OnClickListener {
EditText distanceCondition;
EditText timeCondition;
EditText countCondition;
String distance;
String time;
String count;
String topic;
int notificationID = 1;
int functionality;
int ok = 1;
public void mqttconnect(final String topic, final String message){
final MqttAndroidClient mqttAndroidClient = new MqttAndroidClient(this.getApplicationContext(), "tcp://192.168.1.36", "androidSampleClient");
mqttAndroidClient.setCallback(new MqttCallback() { //iot.eclipse.org:1883
public void connectionLost(Throwable cause) {
System.out.println("Connection was lost!");
public void messageArrived(String topic, MqttMessage message) throws Exception {
System.out.println("Message Arrived!: " + topic + ": " + new String(message.getPayload()));
//displayNotification("DETECT MOVEMENT! visit LCESS app now.");
JSONObject inf = new JSONObject(Arrays.toString(message.getPayload()));
try {
if (inf.optString("Functionality").equals(6)) {
if (inf.optString("ok").equals(1)) {
if (inf.optString("Functionality").equals(7)) {
displayNotification("DETECT MOVEMENT IN" + inf.optString("Distance") + " CM! visit LCESS app now.");
if (inf.optString("Functionality").equals() {
displayNotification("DETECT MOVEMENT IN" + inf.optString("Time") + " HOURS! visit LCESS app now.");
if (inf.optString("Functionality").equals(9)) {
displayNotification("DETECT MOVEMENT IN" + inf.optString("Distance") + " CM and in " + inf.optString("Time") + " HOURS! visit LCESS app now.");
if (inf.optString("Functionality").equals(10)) {
displayNotification("DETECT " + inf.optString("Count") + " OBJECTS/PERSONS! visit LCESS app now.");
catch (Exception functionality){
public void deliveryComplete(IMqttDeliveryToken token) {
System.out.println("Delivery Complete!");
try {
mqttAndroidClient.connect(null, new IMqttActionListener() {
public void onSuccess(IMqttToken asyncActionToken) {
System.out.println("Connection Success!");
try {
System.out.println("Subscribing to: "+ topic);
mqttAndroidClient.subscribe(topic, 0);
System.out.println("Subscribed to: "+ topic);
System.out.println("Publishing message..");
mqttAndroidClient.publish(topic, new MqttMessage(message.getBytes()));
} catch (MqttException ex) {
public void onFailure(IMqttToken asyncActionToken, Throwable exception) {
System.out.println("Connection Failure!");
public JSONObject sendJSONmessage() {
topic = "Mesurement";
distance = distanceCondition.getText().toString();
time = timeCondition.getText().toString();
count = countCondition.getText().toString();
JSONObject post_dict = new JSONObject();
try {
post_dict.put("Topic", topic);
post_dict.put("ok" ,ok);
post_dict.put("Functionality", functionality);
post_dict.put("Distance", distance);
post_dict.put("Time", time);
post_dict.put("Count", count);
} catch (JSONException e) {
e.printStackTrace();
if (post_dict.length() > 0) {
System.out.println(post_dict);
return post_dict;
protected void displayNotification(CharSequence contentText){
Intent i = new Intent(this, NotificationActivity.class);
i.putExtra("notificationID", notificationID);
PendingIntent pendingIntent = PendingIntent.getActivity(this, 0, i, 0);
NotificationManager nm = (NotificationManager)getSystemService(NOTIFICATION_SERVICE);
CharSequence ticker ="Notification in LCESS";
CharSequence contentTitle = "LCESS";
Notification noti = new NotificationCompat.Builder(this)
.setContentIntent(pendingIntent)
.setTicker(ticker)
.setContentTitle(contentTitle)
.setContentText(contentText)
.setSmallIcon(R.drawable.lcess)
.addAction(R.drawable.lcess, ticker, pendingIntent)
.setVibrate(new long[] {100, 250, 100, 500})
.build();
nm.notify(notificationID, noti);
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_main);
distanceCondition = (EditText) findViewById(R.id.edit_detectDistanceCondition);
timeCondition = (EditText) findViewById(R.id.edit_detectTimeCondition);
countCondition = (EditText) findViewById(R.id.edit_countDetects);
Button button_detectDistance = (Button) findViewById(R.id.button_detectDistance);
Button button_detectDistanceCondition = (Button) findViewById(R.id.button_detectDistanceCondition);
Button button_detectTimeCondition = (Button) findViewById(R.id.button_detectTimeCondition);
Button button_detectIfAllCondition = (Button) findViewById(R.id.button_detectIfAllCondition);
Button button_count = (Button) findViewById(R.id.button_count);
assert button_detectDistance != null;
/*button_detectDistance.setOnClickListener(new View.OnClickListener() {
public void onClick(View v) {
functionality = 1;
mqttconnect("Device1/Detect", sendJSONmessage().toString());
button_detectDistance.setOnClickListener(this);
assert button_detectDistanceCondition != null;
button_detectDistanceCondition.setOnClickListener(this);
assert button_detectTimeCondition != null;
button_detectTimeCondition.setOnClickListener(this);
assert button_detectIfAllCondition != null;
button_detectIfAllCondition.setOnClickListener(this);
assert button_count != null;
button_count.setOnClickListener(this);
public void onClick(View v){
if (R.id.button_detectDistance==v.getId()){
functionality = 1;
mqttconnect("Mesurement", sendJSONmessage().toString());
else if (R.id.button_detectDistanceCondition==v.getId()){
functionality = 2;
mqttconnect(sendJSONmessage().optString(topic), sendJSONmessage().toString());
else if (R.id.button_detectTimeCondition==v.getId()){
functionality = 3;
else if (R.id.button_detectIfAllCondition==v.getId()){
functionality = 4;
mqttconnect("Device1/Detect1", sendJSONmessage().toString());
else if (R.id.button_count==v.getId()){
functionality = 5;
First, I created the Mqtt class to publish and subscribe to the topic, After, the class to publish the message that I need in JSON format.
The next class I use it to display a notification. And finally, onCreate() and onClick classes where I declared my buttons, edittext... And where I put the conditions to publish a message. More concretly, when push a button, I publish a message in a topic with JSON format.
The App run well. But the question is: How I can publish ONLY one message in a broker?
In the attached picture you can see how publish 5 message when I press the button.
In red you can see the message published 5 or 6 times
Current Time: Thu Apr 18 23:15:13 GMT 2024
Powered by FUDForum. Page generated in 0.03105 seconds
