Can't resolve target platform [message #1746690] |
Thu, 03 November 2016 09:46 |
Vlad Dumitrescu Messages: 431 Registered: July 2009 Location: Gothenburg |
Hi all,
I am getting crazy here and can't find any other references to similar problems newer than 2012. I'm not sure if it's a PDE or P2 problem.
When I try to reload a target file, I started getting errors about not being able to satisfy dependencies to equinox.launchers and SWT from other platforms. This same target and the same workspace and eclipse installations I have used for a couple of months ago, and it was working fine. I tried cleaning up, reinstalling, restoring from git, etc but the results are the same.
Strangely, building with maven and using the very same target works like it should.
I have a weak memory that I had the same problem when setting up the projects in the beginning, but somehow that got fixed and I didn't write down what made it work. It kept working for a long while after that, but now when reopening the projects after a pause it happens again...
I tried with both Mars and Neon, and both the respective update sites. If anyone has any ideas what could be wrong, I will be forever grateful!
best regards,
Vlad
FUDForum. Page generated in 0.02782 seconds
