Re: Implementing own viewer for EMF Compare [message #1746919 is a reply to message #1746909] |
Mon, 07 November 2016 16:43  |
Hi Conor,
The decoupling we have done between ide and rcp is not "final" and we might very well be able to pull some things out and into the rcp plugin if you think it is possible. The main issue here is that we do not have an rcp use case for the emf compare structure and content viewers yet (iirc, the core content and structure viewers from the platform compare plugin have a hard dependancy on ide.ui).
If you need things in the rcp plugin, do not hesitate to try and pull them out to see if it is at all doable, then push this as a gerrit review for us to include. We'll gladly review any change request and help with finalizing it if necessary. There'll likely be a need to preserve the "current" APIs but that can probably be done without too much trouble.
Laurent Goubet
Obeo
FUDForum. Page generated in 0.02182 seconds
