Re: [CDO] Programmatically adding securityManager [message #1746572 is a reply to message #1746561] |
Tue, 01 November 2016 07:59 |
This is the relevant excerpt from org.eclipse.emf.cdo.server.spi.security.SecurityManagerFactory.Default.create():
List<String> tokens = StringUtil.split(description, ":", "()");
String repositoryName = tokens.get(0);
String realmPath = tokens.get(1);
ISecurityManager securityManager = SecurityManagerUtil.createSecurityManager(realmPath);
for (int i = 2; i < tokens.size(); i++)
String token = tokens.get(i);
CommitHandler handler = getHandler(container, token);
((InternalSecurityManager)securityManager).addCommitHandler(handler);
if (securityManager instanceof InternalSecurityManager)
((InternalSecurityManager)securityManager).setRepository((InternalRepository)RepositoryFactory.get(container, repositoryName));
All the wiring is then done automatically by org.eclipse.emf.cdo.server.internal.security.SecurityManager.init().
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Programmatically adding securityManager [message #1746775 is a reply to message #1746745] |
Fri, 04 November 2016 13:16 |
John Conlon Messages: 35 Registered: July 2009 |
Member |
Modified my initialization:
private void initSecurity(ISecurityManager securityManager) {
if (securityManager instanceof InternalSecurityManager) {
((InternalSecurityManager) securityManager).setRepository((InternalRepository) repository);
LifecycleUtil.activate(securityManager);
Got closer but now I get exceptions:
[INFO] Security realm created in /security
[WARN] Problem while rolling back the transaction
org.eclipse.net4j.db.DBException: Schema locked: REPO1
at org.eclipse.net4j.internal.db.ddl.DBSchema.assertUnlocked(DBSchema.java:280)
at org.eclipse.net4j.internal.db.ddl.DBSchema.removeTable(DBSchema.java:211)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.removeClassMapping(AbstractMappingStrategy.java:695)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.mapClasses(AbstractMappingStrategy.java:666)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.mapPackageInfos(AbstractMappingStrategy.java:646)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.mapPackageUnits(AbstractMappingStrategy.java:635)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.removeMapping(AbstractMappingStrategy.java:600)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.doRollback(DBStoreAccessor.java:745)
at org.eclipse.emf.cdo.spi.server.StoreAccessorBase.rollback(StoreAccessorBase.java:203)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.rollback(TransactionCommitContext.java:1287)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.handleException(TransactionCommitContext.java:722)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:660)
at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:48)
at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
at org.eclipse.emf.cdo.internal.server.Repository.commitUnsynced(Repository.java:1144)
at org.eclipse.emf.cdo.internal.server.Repository.commit(Repository.java:1137)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:293)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:101)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:110)
at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:98)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:100)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:369)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:73)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:67)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:275)
at org.eclipse.net4j.signal.Signal.run(Signal.java:154)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
2016-11-04 08:09:50,215, WARN, com.verticon.cdo.server.provider.RepositoryServer, com.verticon.cdo.server.provider.RepositoryServer$1@246d00c8 Problem while rolling back the transaction
org.eclipse.net4j.util.WrappedException: org.eclipse.emf.cdo.util.CommitException: Rollback in DBStore: org.eclipse.net4j.db.DBException: org.h2.jdbc.JdbcSQLException: Value too long for column "CDO_CLASS VARCHAR(60)": "'http://www.eclipse.org/emf/CDO/security/4.1.0#//FilterPermission' (64)"; SQL statement:
INSERT INTO CDO_OBJECTS(CDO_ID,CDO_CLASS,CDO_CREATED) VALUES (?, ?, ?) [22001-192]
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.ObjectTypeTable.putObjectType(ObjectTypeTable.java:136)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.DelegatingObjectTypeMapper.putObjectType(DelegatingObjectTypeMapper.java:71)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalMappingStrategy.putObjectType(AbstractHorizontalMappingStrategy.java:87)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalBranchingClassMapping.writeRevision(HorizontalBranchingClassMapping.java:715)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.writeRevision(DBStoreAccessor.java:591)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.writeRevisions(DBStoreAccessor.java:571)
at org.eclipse.emf.cdo.spi.server.StoreAccessor.doWrite(StoreAccessor.java:98)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.doWrite(DBStoreAccessor.java:831)
at org.eclipse.emf.cdo.spi.server.StoreAccessorBase.write(StoreAccessorBase.java:152)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:651)
Caused by: org.h2.jdbc.JdbcSQLException: Value too long for column "CDO_CLASS VARCHAR(60)": "'http://www.eclipse.org/emf/CDO/security/4.1.0#//FilterPermission' (64)"; SQL statement:
at org.h2.message.DbException.getJdbcSQLException(DbException.java:345)
at org.h2.message.DbException.get(DbException.java:179)
at org.h2.table.Column.validateConvertUpdateSequence(Column.java:335)
at org.h2.table.Table.validateConvertUpdateSequence(Table.java:784)
at org.h2.command.dml.Insert.insertRows(Insert.java:151)
at org.h2.command.dml.Insert.update(Insert.java:114)
at org.h2.command.CommandContainer.update(CommandContainer.java:98)
at org.h2.command.Command.executeUpdate(Command.java:258)
at org.h2.jdbc.JdbcPreparedStatement.executeUpdateInternal(JdbcPreparedStatement.java:160)
at org.h2.jdbc.JdbcPreparedStatement.executeUpdate(JdbcPreparedStatement.java:146)
at org.eclipse.net4j.db.jdbc.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:81)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.ObjectTypeTable.putObjectType(ObjectTypeTable.java:120)
... 27 more
at org.eclipse.net4j.util.WrappedException.wrap(WrappedException.java:54)
at org.eclipse.emf.cdo.server.internal.security.SecurityManager.init(SecurityManager.java:590)
at org.eclipse.emf.cdo.server.internal.security.SecurityManager.doActivate(SecurityManager.java:848)
at org.eclipse.net4j.util.lifecycle.Lifecycle.internalActivate(Lifecycle.java:76)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:162)
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:127)
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:117)
at com.verticon.cdo.server.provider.RepositoryServer.initSecurity(RepositoryServer.java:496)
at com.verticon.cdo.server.provider.RepositoryServer.modified(RepositoryServer.java:479)
at com.verticon.cdo.server.provider.RepositoryServer.activate(RepositoryServer.java:295)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.apache.felix.scr.impl.helper.BaseMethod.invokeMethod(BaseMethod.java:222)
at org.apache.felix.scr.impl.helper.BaseMethod.access$500(BaseMethod.java:37)
at org.apache.felix.scr.impl.helper.BaseMethod$Resolved.invoke(BaseMethod.java:615)
at org.apache.felix.scr.impl.helper.BaseMethod.invoke(BaseMethod.java:499)
at org.apache.felix.scr.impl.helper.ActivateMethod.invoke(ActivateMethod.java:295)
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:302)
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:113)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:866)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:833)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:724)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:399)
at org.apache.felix.scr.impl.config.ConfigurableComponentHolder.configurationUpdated(ConfigurableComponentHolder.java:424)
at org.apache.felix.scr.impl.config.ConfigurationSupport.configurationEvent(ConfigurationSupport.java:315)
at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.sendEvent(ConfigurationManager.java:2046)
at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.run(ConfigurationManager.java:2014)
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:103)
Caused by: org.eclipse.emf.cdo.util.CommitException: Rollback in DBStore: org.eclipse.net4j.db.DBException: org.h2.jdbc.JdbcSQLException: Value too long for column "CDO_CLASS VARCHAR(60)": "'http://www.eclipse.org/emf/CDO/security/4.1.0#//FilterPermission' (64)"; SQL statement:
... 27 more
at org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:89)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commitSynced(CDOTransactionImpl.java:1316)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1290)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1257)
at org.eclipse.emf.cdo.server.internal.security.SecurityManager.init(SecurityManager.java:586)
... 29 more
FUDForum. Page generated in 0.03180 seconds
