Re: Easier way to test p2 provision [message #1746434 is a reply to message #1746403] |
Fri, 28 October 2016 15:40 |
Ed Merks Messages: 33133 Registered: July 2009 |
Start out small with just a base that works. The IDE that's successfully create will reference the original product setup, so you can progressively add things to the p2 task in the product setup (or add additional p2 tasks, which might make it easier to manage in the long term because you have a better idea of which IUs are coming from which repositories) and then you can run p2 task in that IDE, gradually building it up to the complete set of things you want. Then you can test again that you can create one from scratch with the installer. You can overwrite a directory as well; no need to delete it each time it fails...
Ed Merks
FUDForum. Page generated in 0.01763 seconds
