Re: ToolModelingChain [message #1746415 is a reply to message #1746405] |
Fri, 28 October 2016 12:30   |
Garros JPG Messages: 13 Registered: October 2016 |
I have another question. for example you want to consume a resource from an architecture domain. In toolchain modeling you must specify the ArchitectureResource totally. You can't use predefined type in lyo like the ArchitectureResource class. Is it right ? If no I am interesting in how said that a Resource in specification can extends a exisiting lyo type. If yes it is possible to fix this problem or not ?
[Updated on: Fri, 28 October 2016 12:31] Report message to a moderator
Re: ToolModelingChain [message #1749055 is a reply to message #1746401] |
Thu, 01 December 2016 14:05   |
Jad El-khoury Messages: 46 Registered: August 2015 |
Member |
(A bit late to answer here maybe, but I just discovered this thread)
Currently, you have to specify the ArchitectureResource in the model, which is admittedly a waste of time, since it is a standard resource definition. One solution is to have a library of models for the standard OSLC domain specifications, that one can simply load and reused.
Would that help?
As for extending a resource, each resource definition includes a "extends" property which you can use to specify the other resource you are generalizing. Did you try using that?
/Jad
Btw, I have updated the instructions on https://wiki.eclipse.org/Lyo/ToolchainModellingAndCodeGenerationWorkshop#Run_the_adaptor to clarify the starting page of the server, and how to get started and use the jsp pages.
Re: ToolModelingChain [message #1759938 is a reply to message #1746401] |
Thu, 20 April 2017 08:04  |
Member |
The OSLC vocabluaries are already there, as well as FOAF, DCTerms, etc.
And the models are public now.
Instructions:
Clone the https://git.eclipse.org/gitroot/lyo/org.eclipse.lyo.tools.git git repository, and import a project called "org.eclipse.lyo.tools.domainmodels". This project already models many of the OSLC domains, which you can simply import and use in your own toolchain model. How?
1. Import the project into your workspace
2. In your modelling project, right click on the "Project Dependecies" in the Project Explorer tree, and select "Add Model"
3. Select "Browse Workspace"
4. Select the OSLCDomainSpecs.xml file under the org.eclipse.lyo.tools.domainmodels" project. A set of domains are now available in your project to use.
5. In your own SpecificationDiagram, you can now drag and drop any domain under the xml tree to visually present it.
6. In your Adaptor Models, you can also drag-drop resources to allocate them to different adaptors.
Note also that you can explore the OSLC models graphically by expanding the xml file within the org.eclipse.lyo.tools.domainmodels project just like a toolchain model but it only contains specs.
FUDForum. Page generated in 0.02443 seconds
