Re: [GEF4] Bad Performance on Scaling with larger amount of Nodes [message #1746429 is a reply to message #1746385] |
Fri, 28 October 2016 14:27 |
Hi Uwe,
if I understand correctly, you are using individual listeners to keep the stroke widths of all parts constant while zooming. However, you could centralize the transformation listener by using one centralized DoubleProperty that computes the stroke-width in response to contentTransform changes. The individual stroke-width properties could then be bound to the centralized property.
> Setting the stroke width seems to result in a exponential increase of the effort, because every change of the stroke width leads to a recalculation of the hole canvas, including all parts.
I do not quite understand the "recalculation" of the parts/canvas. A part can be refreshed to adapt its visualization to its content, but this should only be done in response to content changes. Would you please explain the observed behavior more precisely?
There should not be a recalculation that is is triggered by the stroke width, except for the positioning of feedback or handles, and the content-bounds of the canvas (which are only updated if the bounds of a visual at the edge of the content-bounds is changed).
Matthias
FUDForum. Page generated in 0.03300 seconds
