Home » Modeling » M2T (model-to-text transformation) » Acceleo (Run configuration)
Acceleo (Run configuration) [message #1746216] Tue, 25 October 2016 13:06 Go to next message
Raoudha Saida is currently offline Raoudha SaidaFriend
Member
I got this error when I do "Run configuration" in acceleo.
'An internal error occurred during: "Launching conf-trans2".
org/eclipse/osgi/framework/internal/core/AbstractBundle'
Can one help me.
Thanks in advance.
Re: Acceleo (Run configuration) [message #1746288 is a reply to message #1746216] Wed, 26 October 2016 13:26 Go to previous messageGo to next message
Member
Can one help me to solve this error.
Thanks a lot.
index.php/fa/27445/0/
[Updated on: Fri, 28 October 2016 09:10]
Report message to a moderator
Re: Acceleo (Run configuration) [message #1746289 is a reply to message #1746288] Wed, 26 October 2016 13:31 Go to previous messageGo to next message
Member
No Message Body
[Updated on: Fri, 28 October 2016 09:09]
Re: Acceleo (Run configuration) [message #1746662 is a reply to message #1746289] Wed, 02 November 2016 15:08 Go to previous message
Laurent Goubet is currently offline Laurent GoubetFriend
Please go to Window > Show View and select "error log". You should be able to see the actual stack trace of the error you get in that new view, please paste it here.
Laurent Goubet
Obeo
Previous Topic:Workflow configuration error - classes not found
Next Topic:[Acceleo] Problem starting Acceleo from within Magicdraw Plugin
Current Time: Sun Jun 16 18:45:12 GMT 2019
Powered by FUDForum. Page generated in 0.01470 seconds
