Re: Opening a WindowsBuilder window in Sirius [message #1746166 is a reply to message #1746117] |
Mon, 24 October 2016 12:02 |
Hi Omid,
Could you precise what do you describe with "a new with Eclipse WindowBuilder created window will be shown" ?
Is it an editor defined with Sirius Specification Model ? In this case, if it is a diagram, you might use the Navigation model operation inside a popup menu defined in the specification model, see Tool organization part of the Specifier guide.
If you want to open a non-Sirius Editor, you can complete the menu using the preceding tools and delegates the opening of your editor in a Java service (see writing queries), or you can use the eclipse menus extensions points (org.eclipse.ui.menus or org.eclipse.ui.popupmenus) and code your action.
Maxime - Obeo
[Updated on: Mon, 24 October 2016 12:03] Report message to a moderator
Re: Opening a WindowsBuilder window in Sirius [message #1746261 is a reply to message #1746186] |
Wed, 26 October 2016 08:46 |
Hi Omid,
If you use an External Java Action, you need to declare it in the plugin.xml and then to launch a runtime to deploy your modeler in order to be able to use it. You can not do the "live editing" of your modeler with the tools which use the external java action. I would recommand to use a Popup menu and and Operation Action with some calls to Java services instead of this ExternalJavaAction.
Maxime - Obeo
FUDForum. Page generated in 0.03239 seconds
