Home » Modeling » TMF (Xtext) » Please use the TypeReference(packageName, className)
Please use the TypeReference(packageName, className) [message #1745995] Thu, 20 October 2016 05:57 Go to next message
Hi everyone,
When I try to launch the generation of Xtext artifacts I get the following error:
[ERROR]: GeneratorException: (Element: -UNKNOWN-; Reported by: XtextGenerator)
	 java.lang.IllegalArgumentException: Cannot determine the package name of 'GS.GSPackage'. Please use the TypeReference(packageName, className) constructor
Could someone explain to me please the cause of this error.
Also i dont understand why in my manifest file the serializer plug-in is missing. Is that related to my previous error.
thanks in advance
Best regards
Re: Please use the TypeReference(packageName, className) [message #1745997 is a reply to message #1745995] Thu, 20 October 2016 06:07 Go to previous messageGo to next message
Xtext cannot handle your naming convestions. please create a bug at https://github.com/eclipse/xtext-core
do you have the package name under control?
Re: Please use the TypeReference(packageName, className) [message #1746006 is a reply to message #1745997] Thu, 20 October 2016 07:12 Go to previous messageGo to next message
Thanks Christian ,
As always you're here to rescue us.
Yes i have the package name under control and i can change it if needed.
Pease find below my simple MM and the grammar that a am trying to define.
Re: Please use the TypeReference(packageName, className) [message #1746009 is a reply to message #1746006] Thu, 20 October 2016 07:42 Go to previous messageGo to next message
can you change name of the package to gs (lower case)
Re: Please use the TypeReference(packageName, className) [message #1746023 is a reply to message #1746009] Thu, 20 October 2016 11:25 Go to previous messageGo to next message
Thanks Christian,
Indeed my problem is solved. can I have more details about the source of the problem.
Re: Please use the TypeReference(packageName, className) [message #1746025 is a reply to message #1746023] Thu, 20 October 2016 11:52 Go to previous messageGo to next message
as i said: please file a bug so that this can be fixed. t
he implementation of
org.eclipse.xtext.xtext.generator.model.TypeReference.getPackageName(String, boolean)
expects the emf package to stick to java naming conventions
a.b.c.XyzPackage
Re: Please use the TypeReference(packageName, className) [message #1746095 is a reply to message #1746025] Fri, 21 October 2016 10:45 Go to previous messageGo to next message
Its done
Thanks again
Re: Please use the TypeReference(packageName, className) [message #1755141 is a reply to message #1746095] Tue, 28 February 2017 06:42 Go to previous messageGo to next message
What is the status of this bug? I have the same issue.
Re: Please use the TypeReference(packageName, className) [message #1755144 is a reply to message #1755141] Tue, 28 February 2017 07:02 Go to previous messageGo to next message
there is no news. this bug is still open.
Re: Please use the TypeReference(packageName, className) [message #1755145 is a reply to message #1755144] Tue, 28 February 2017 07:03 Go to previous messageGo to next message
https://github.com/eclipse/xtext-core/issues/161
Re: Please use the TypeReference(packageName, className) [message #1755148 is a reply to message #1755145] Tue, 28 February 2017 07:26 Go to previous message
Previous Topic:How to integrating OCL types in Xtext grammar
Next Topic:Loading resources in web editor
Current Time: Sat Jul 12 16:30:46 EDT 2025
Powered by FUDForum. Page generated in 0.05712 seconds
