Putting Buttons into Table Headline [message #1745846] |
Tue, 18 October 2016 10:54 |
I have a table where the bottom right headline is nearly empty and would allow me to build a more intuitive and concise UI if I could put there in addition to the headline text (left aligned) two buttons (right aligned).
I already googled a bit and looked at the code of table and didn't find an easy solution.
Does anybody know if such a thing would be possible?
And maybe even more important do you think it would be a good idea or am I violating good UI design on many levels?
Maybe at last a short overview on the use-case the table in question is in a property sheet and holds a list of items. The buttons would be add and remove and sofar placing the buttons on all sides of the table looked other awkward, required quite some mouse movement or used a lot of space. Therefore I'm looking for alternatives.
FUDForum. Page generated in 0.02280 seconds
