Home » Eclipse Projects » BIRT » Use XML datasource values to change Master page properties
Use XML datasource values to change Master page properties [message #1745795] Mon, 17 October 2016 14:57
victor gonzalez is currently offline victor gonzalezFriend
I started using Birt a days ago, I´ve successfully created a DataSet from a Data Source and I´ve shown it´s values in a dynamic text. Now im trying to get this values in runtime and use it to set differents properties i.e: having a <Orientation>Landscape</Orientation> set the master page Orientation to landscape. I found the way to change the orientation and a I can literally put "landscape" but it seems not possible to take this value from the dataSource.
it? It´s possible?
Thank you in advance
Previous Topic:Birt viewer on a Standalone java application whitout server
Next Topic:duplicate post, admin delete it please
Current Time: Fri Feb 28 13:16:03 GMT 2020
Powered by FUDForum. Page generated in 0.02963 seconds
