[SOLVED]Unresolved requirement in Vorto IDE for contributor [message #1745728] |
Sun, 16 October 2016 17:29 |
Nyiri András Messages: 14 Registered: September 2016 |
I'm new to Vorto, and after trying out javabean and web application generator from the tutorial I thoght it's time to getting to know more about the works of the code generator projects.
So I installedthe Vorto IDE for contributor profile with Yatta. After it finished the building of the workspace I tried to run the 'org.eclipse.vorto.codegen.examples.javabean' project as an Eclipse application. When it's starting it prints several errors to the console like this one:
!ENTRY org.eclipse.vorto.editor.ui 4 0 2016-10-16 19:13:18.471
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.vorto.editor.ui [534]
Unresolved requirement: Require-Bundle: org.eclipse.vorto.core.ui
-> Bundle-SymbolicName: org.eclipse.vorto.core.ui; bundle-version="0.9.0.qualifier"; singleton:="true"
org.eclipse.vorto.core.ui [518]
Unresolved requirement: Require-Bundle: org.apache.commons.collections
at org.eclipse.osgi.container.Module.start(Module.java:434)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
After scrolling throw the errors similar like this it seems like the root cause is an unresolved requirement 'org.apache.commons.collections'. Can anyone help me with this?
EDIT:
It looks like selecting an other target platform solved this. Go to Window > Preferences... > Plug-in Development > Target Platform, then select 'target-definitions /org.eclipse.vorto.targetplatform/vorto.target'.
[Updated on: Sun, 16 October 2016 17:40] Report message to a moderator
FUDForum. Page generated in 0.02200 seconds
