Home » Eclipse Projects » RCP Testing Tool » Custom ECL Commands(Returning a value from the custom command to the code where it was called)
Custom ECL Commands [message #1745530] Wed, 12 October 2016 07:27 Go to next message
Komal Sorte is currently offline Komal SorteFriend
I've tried to create an ecl custom command via following the instructions given on http://help.xored.com/display/ECL/New+Command+Guide
On the above site they have implemented ICommandService Interface, this works perfectly fine but now I want to return a String object from it to the code where this command was called but the interface only lets return an object of IStatus type.
So please suggest solutions or hints for the above problem.
Komal S
Re: Custom ECL Commands [message #1749203 is a reply to message #1745530] Sat, 03 December 2016 01:43 Go to previous messageGo to next message
Pascal Rapicault is currently offline Pascal RapicaultFriend
The output of a command is not returned from the service implementation. Instead it is returned through a special output object that you obtain from the context passed as a parameter to your command implementation.
In the page you refer to, the line is IPipe output = context.getOutput();
You can also return EMF objects defined in your command. We use that in EGerrit http://git.eclipse.org/c/egerrit/org.eclipse.egerrit.git/tree/org.eclipse.egerrit.ui.tests/src/org/eclipse/egerrit/internal/rcptt/support/CreateReviewService.java
HTH
Re: Custom ECL Commands [message #1750135 is a reply to message #1749203] Fri, 16 December 2016 10:42 Go to previous message
Artem Kovalev is currently offline Artem KovalevFriend
Hi Komal,
Or you can extends org.eclipse.rcptt.ecl.runtime.SingleCommandService for your ecl service.
Previous Topic:problems converting long
Next Topic:How to access resource via JNDI in RCPTT
Current Time: Tue Apr 16 18:06:29 GMT 2024
Powered by FUDForum. Page generated in 0.66007 seconds
