Export JAR file with plug-in dependency [message #1745355] |
Fri, 07 October 2016 21:58 |
Chung-Ling Lin Messages: 39 Registered: December 2011 |
Member |
I have a general question about the dependency of the plug-ins of the exported JAR file.
For example, I have a java plug-in (e.g. project A) which requires some required plug-ins (e.g. org.eclipse.emf.ecore, org.eclipse.m2m.atl, etc.) to be specified in the MANIFEST.MF of my project A. And I would like to export project A to a JAR file (e.g. A.jar) so other developers can use my project.
But after I create another Java project B and import my A.jar, I found that I have run time error when using the classes and method in project A if I didn't include all required plug-ins described above ( (e.g. org.eclipse.emf.ecore, org.eclipse.m2m.atl, etc.) in the MANIFEST.MF of project B.
I would like know is it possible to export a JAR file with all required plug-ins specify in the exported JAR file so the users can import my JAR file and use it directly without requiring them manually add all of the required plug-ins in their own projects.
Thank you very much for you help.
Best Regards,
Chung-Ling Lin
[Updated on: Fri, 07 October 2016 22:00] Report message to a moderator
FUDForum. Page generated in 0.02970 seconds
