Home » Eclipse Projects » NatTable » TreeGridWithCheckBoxFieldsExample Sortation Problem(TreeGridWithCheckBoxFieldsExample Sortation Problem when data of root set null)
TreeGridWithCheckBoxFieldsExample Sortation Problem [message #1745325] Fri, 07 October 2016 13:07 Go to next message
cenk Mising name is currently offline cenk Mising nameFriend
The sortation that in TreeGridWithCheckBoxFieldsExample is working normally. But When changed data of root elements to null(It is below), sortation is not working correctly.
(createDatum(null, "root", false, null);
createDatum(null, "root2", false, null);
For this problem, we are add "comparators.add(treeComparator);" before "return new ComparatorChain<T>(comparators).compare(o1, o2);" line in SortableTreeComparator.java. I see it is working correctly. Is it a bug?.Can you check it is ok.
import java.util.ArrayList;
import java.util.Collections;
import java.util.Comparator;
import java.util.List;
import org.eclipse.nebula.widgets.nattable.sort.ISortModel;
import org.eclipse.nebula.widgets.nattable.sort.SortDirectionEnum;
import org.eclipse.nebula.widgets.nattable.util.ComparatorChain;
public class SortableTreeComparator<T> implements Comparator<T> {
    private final Comparator<T> treeComparator;
    private final ISortModel sortModel;
    public SortableTreeComparator(Comparator<T> treeComparator, ISortModel sortModel) {
        this.treeComparator = treeComparator;
        this.sortModel = sortModel;
    @SuppressWarnings({ "rawtypes", "unchecked" })
    public int compare(T o1, T o2) {
        int treeComparatorResult = this.treeComparator.compare(o1, o2);
        if (treeComparatorResult == 0) {
            return 0;
        } else {
            List<Integer> sortedColumnIndexes = this.sortModel.getSortedColumnIndexes();
            if (sortedColumnIndexes != null && sortedColumnIndexes.size() > 0) {
                List<Comparator<T>> comparators = new ArrayList<Comparator<T>>();
                for (int sortedColumnIndex : sortedColumnIndexes) {
                    // get comparator for column index... somehow
                    List<Comparator> columnComparators =
                            this.sortModel.getComparatorsForColumnIndex(sortedColumnIndex);
                    if (columnComparators != null) {
                        SortDirectionEnum sortDirection = this.sortModel.getSortDirection(sortedColumnIndex);
                        for (Comparator columnComparator : columnComparators) {
                            switch (sortDirection) {
                                case ASC:
                                    comparators.add(columnComparator);
                                    break;
                                case DESC:
                                    comparators.add(Collections.reverseOrder(columnComparator));
                                    break;
                //*******added line
                comparators.add(treeComparato)
            } else {
                return treeComparatorResult;
Re: TreeGridWithCheckBoxFieldsExample Sortation Problem [message #1745490 is a reply to message #1745325] Tue, 11 October 2016 13:43 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
From testing this it looks ok. Feel free to create a ticket and provide a patch via Gerrit.
Re: TreeGridWithCheckBoxFieldsExample Sortation Problem [message #1746127 is a reply to message #1745490] Sat, 22 October 2016 19:42 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=506394
Previous Topic:[Help] Freeze Rows/Colums freezes all indexes down to 0
Next Topic:Traversal and MultiLineTextCellEditor
Current Time: Wed Sep 23 13:49:21 GMT 2020
Powered by FUDForum. Page generated in 0.02197 seconds
