Home » Eclipse Projects » Oomph » Installer says that restart needed but I think it is not
Installer says that restart needed but I think it is not [message #1744779] Fri, 30 September 2016 07:52 Go to next message
Felix Dorner is currently offline Felix DornerFriend
When the installer logs what's shown on the bottom, what is actually being installed that makes a restart necessary? To me it looks like nothing is installed so why need a restart? If I compare the last two entries in the Installation history, it says "There are no differences between the selected inputs"
Adding repository http://dist.springsource.org/snapshot/GRECLIPSE/e4.6/
Adding repository http://download.eclipse.org/egit/updates
Adding repository http://download.eclipse.org/releases/neon/201609281000
Adding repository http://download.eclipse.org/oomph/updates/milestone/latest
Calculating requirements and dependencies.
Computing prerequisite plan
Preparing to commit the provisioning operation.
Committing the provisioning operation.
Took 5 seconds.
A restart is needed for the following reasons:
- New software has been installed.
Press Finish to restart now or Cancel to restart later.
[Updated on: Fri, 30 September 2016 08:04]
Report message to a moderator
Re: Installer says that restart needed but I think it is not [message #1744806 is a reply to message #1744779] Fri, 30 September 2016 10:26 Go to previous messageGo to next message
Normally it would say if there is nothing to install and then not need a restart, so presumably it did commit some change to the profile. But again, unless I have steps to reproduce such a problem, it's hard to say what's going one.
Re: Installer says that restart needed but I think it is not [message #1744895 is a reply to message #1744806] Sat, 01 October 2016 19:56 Go to previous message
Ok sure. Here too, it stopped doing this for now. When it happens again I'll try to debug it and come back with results.
Previous Topic:Reload target platform imports missing projects
Next Topic:Update an already eclipse installed through oomph
Current Time: Sat May 30 18:54:19 GMT 2020
Powered by FUDForum. Page generated in 0.02011 seconds
