Home » Eclipse Projects » BIRT » Run birt from command line fails 4.4
Run birt from command line fails 4.4 [message #1744667] Thu, 29 September 2016 11:31 Go to next message
Nick Barnes is currently offline Nick BarnesFriend
Hi Guys,
Can someone help please. I've got two machines where this is working and for the life of me I can't get rid of this error. The setup's are identical...or that's what I though.
I'm getting this error
Caused by: org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.birt.report.engine.emitter.prototype.excel was unable to
The paths seem correct I've "echo $BIRTCLASSPATH" and seems fine
/java/birtosgi/reportengine/genreport.sh java/birtosgi/reportengine/samples/test.rptdesign
mkdir: 001-2128 Error found creating directory /java/birtosgi/ReportEngine/tmpdir/workspace_dtp. File exists.
Echo'd PATH
/java/birtosgi/ReportEngine/lib/scriptapi.jar:/java/birtosgi/ReportEngine/lib/org.w3c.css.sac_1.3.0.v200805290154.jar:/java/birto
sgi/ReportEngine/lib/org.eclipse.emf.ecore.xmi_2.10.0.v20140514-1158.jar:/java/birtosgi/ReportEngine/lib/org.eclipse.emf.ecore_2.
10.0.v20140514-1158.jar:/java/birtosgi/ReportEngine/lib/org.eclipse.emf.common_2.10.0.v20140514-1158.jar:/java/birtosgi/ReportEng
ine/lib/org.eclipse.birt.axis.overlay_4.4.0.v201405191524.jar:/java/birtosgi/ReportEngine/lib/org.apache.commons.codec_1.3.0.v201
101211617.jar:/java/birtosgi/ReportEngine/lib/odadesignapi.jar:/java/birtosgi/ReportEngine/lib/modelodaapi.jar:/java/birtosgi/Rep
ortEngine/lib/modelapi.jar:/java/birtosgi/ReportEngine/lib/js.jar:/java/birtosgi/ReportEngine/lib/flute.jar:/java/birtosgi/Report
Engine/lib/engineapi.jar:/java/birtosgi/ReportEngine/lib/emitterconfig.jar:/java/birtosgi/ReportEngine/lib/dteapi.jar:/java/birto
sgi/ReportEngine/lib/dataextraction.jar:/java/birtosgi/ReportEngine/lib/dataaggregationapi.jar:/java/birtosgi/ReportEngine/lib/da
taadapterapi.jar:/java/birtosgi/ReportEngine/lib/crosstabcoreapi.jar:/java/birtosgi/ReportEngine/lib/coreapi.jar:/java/birtosgi/R
eportEngine/lib/commons-cli-1.0.jar:/java/birtosgi/ReportEngine/lib/com.ibm.icu_52.1.0.v201404241930.jar:/java/birtosgi/ReportEng
ine/lib/chartitemapi.jar:/java/birtosgi/ReportEngine/lib/chartexamplescoreapi.jar:/java/birtosgi/ReportEngine/lib/chartengineapi.
jar:
Error is
Sep 29, 2016 1:19:04 PM org.eclipse.birt.core.framework.eclipse.EclipsePlatform createFactoryObject
WARNING: CREATE_EXTENSION_FAIL
org.eclipse.birt.core.framework.FrameworkException: CREATE_EXTENSION_FAIL
at org.eclipse.birt.core.framework.eclipse.EclipseConfigurationElement.createExecutableExtension(EclipseConfigurationElem
ent.java:39)
at org.eclipse.birt.core.framework.eclipse.EclipsePlatform.createFactoryObject(EclipsePlatform.java:372)
at org.eclipse.birt.core.framework.Platform$1.run(Platform.java:297)
at java.security.AccessController.doPrivileged(AccessController.java:400)
at org.eclipse.birt.core.framework.Platform.createFactoryObject(Platform.java:293)
at org.eclipse.birt.report.model.api.DesignEngine.<init>(DesignEngine.java:90)
at org.eclipse.birt.report.engine.parser.ReportParser.getDesignHandle(ReportParser.java:142)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.getReportDesignHandle(ReportEngineHelper.java:255)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:274)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:196)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:130)
at org.eclipse.birt.report.engine.api.impl.ReportEngine.openReportDesign(ReportEngine.java:310)
at org.eclipse.birt.report.engine.api.ReportRunner.runAndRenderReport(ReportRunner.java:195)
at org.eclipse.birt.report.engine.api.ReportRunner.execute(ReportRunner.java:168)
at org.eclipse.birt.report.engine.api.ReportRunner.main(ReportRunner.java:127)
Caused by: org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.birt.report.engine.emitter.prototype.excel was unable to load class org.eclipse.birt.report.model.api.impl.DesignEngineFactory.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.jav
a:55)
ent.java:35)
... 14 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.birt.report.model.api.impl.DesignEngineFactory cannot be found by org.ec
lipse.birt.report.engine.emitter.prototype.excel_4.4.0.v201405191524
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:423)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:336)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:328)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at java.lang.ClassLoader.loadClass(ClassLoader.java:731)
Any help would be appreciated. Thanks
Re: Run birt from command line fails 4.4 [message #1744931 is a reply to message #1744667] Mon, 03 October 2016 06:01 Go to previous messageGo to next message
Just a quick update if anyone is reading. I've updated to 4.6 and still getting the same error.
Re: Run birt from command line fails 4.4 [message #1744932 is a reply to message #1744931] Mon, 03 October 2016 06:13 Go to previous message
I've cut back to version 4.4.0 and it's working on this version any idea why the update stopped working ?
Previous Topic:Showing Multiple pages in Footer
Next Topic:java.lang.ClassCastException
Current Time: Sun Jan 26 23:12:41 GMT 2020
Powered by FUDForum. Page generated in 0.01508 seconds
