Re: Registering Metamodels in Java project [message #1744597 is a reply to message #1744591] |
Wed, 28 September 2016 18:01 |
Edouard R. Batot Messages: 100 Registered: March 2015 |
Quote:It doesn't come from EMF itself so knowing what X plug-in is would be good.
I mean that, as an outsider user, I've put X plugins. FIrst to work with some modelling views, then to monitor execution, to enhance debugging... And finally the ATL workbench. I suppose this is when I started to manipulated Ecore artefacts but there are plugin I forget to mentioned because I installed them to "try". Is the last plugin offering the "register metamodel" option, there's no way to verify. No way I know of (until your spy advice ). So, let's call it the X plugin allowing me, in one of its numerous features, to register a metamodel in Ecore by a right click on its name in the Project explorer.
Quote:So you assume it's because you used the installer rather than these just being problem cause by what is installed? What kind of popups?
I'm sure it comes from the installer, since without it I have no trouble. But, honestly Ed, the only hint I have on that topic is that the installer don't (and maybe it can not) take in charge previous versions installed with previous working sets and other previous settings.
Popup suggesting configuration for SVN (when this plugin is not on yet) is the source of that clue. Later, I install SVN, but the problem remains, and popups signaling a SVN problem keep poping : SVN is unstable after an installation with ther installer, it is stable when I use the good old zip files.
Quote:The plug-in spy is very useful.
Thanks thanks thanks ! I just started, as you mentionned, a brand new configuration (Neon-Modelling, and that is the first plugin I'll load).
The problem seems of such a low level that I hesitate between Newcomers and EMF forums..
For now, I will investigate with the new version, the modelling one, with ATL, and spy on the impact of the GUI in the plugin/features dependencies.
It is to mention that I never get Eclipse so unstable. Might be because of Neon, or because of my mis-use, but the dependence is definitively growing on a tool that lose in maneuverability.
Their will be a talk on that topic at MoDELS2016.
Thanks Ed for your attention and advices,
Edouard
|Edit| ATL plugin reminicences behave the same as SVN. Perspective is "available", you can choose it, but it is not working (obviously, since it is not installed).
[Updated on: Wed, 28 September 2016 18:18] Report message to a moderator
FUDForum. Page generated in 0.02938 seconds
