Home » Archived » Eclipse SmartHome » Dynamic Creation and Disposal of Channels(Suggestions on efficient methods to dynamically create, remove and dispose channels)
Dynamic Creation and Disposal of Channels [message #1744112] Thu, 22 September 2016 08:37 Go to next message
I created channels dynamically and linked it to the thing by using ThingBuilder.build() method. For removing the channels, I got the current list of channels using getChannels() method and made a mutable list from it. Then I iterated through the channels found the channelUID match and removed it from the mutable list i created and then again used ThingBuilder.build() using the list I modified. Is this the correct procedure to do this?
Abin
[Updated on: Thu, 22 September 2016 08:45] by Moderator
Re: Dynamic Creation and Disposal of Channels [message #1744160 is a reply to message #1744112] Thu, 22 September 2016 18:49 Go to previous messageGo to next message
I'm afraid that this is currently the only way - it so far was really never a use case to remove channels, but it is a valid requirement of course.
Feel free to enter an issue about that, so that we might enhance the ThingBuilder to also allow removals.
Re: Dynamic Creation and Disposal of Channels [message #1744173 is a reply to message #1744160] Fri, 23 September 2016 03:16 Go to previous messageGo to next message
Thanks Kai for your response and time. I have a few queries on Thing being cached. Where is this implemented? The dynamic channels I created if not removed, is being shown up again when the server is restarted. How can I disable this behaviour? How to ensure the dispose() methods are called of the Things when the server is stopped? When is the handleRemoval() method and when is the dispose() method in thing handler called?
Abin
[Updated on: Fri, 23 September 2016 03:24] by Moderator
Re: Dynamic Creation and Disposal of Channels [message #1744288 is a reply to message #1744173] Sat, 24 September 2016 00:54 Go to previous messageGo to next message
Well, this is the core functionality of the ManagedThingProvider that it persists the Things in a database.
I think this is the same request as https://github.com/eclipse/smarthome/issues/588#issuecomment-226565087 - this indeed is currently not possible, but maybe it is a good idea to change this behavior to not persisting any change. Fancy to enter another issue?
You cannot, the server could also be powered off without you having a chance to do any clean up.
handleRemoval: on a Thing removal (e.g. triggered by the user in the UI)
dispose: upon a bundle shutdown, when the services are stopped in an orderly fashion.
Re: Dynamic Creation and Disposal of Channels [message #1744347 is a reply to message #1744288] Mon, 26 September 2016 04:44 Go to previous messageGo to next message
Thank you so much Kai
Abin
Re: Dynamic Creation and Disposal of Channels [message #1744499 is a reply to message #1744288] Tue, 27 September 2016 09:13 Go to previous messageGo to next message
How do we get the current state of channel in framework? Are there some methods for the developers for fetching the current state of channels? Or should the binding handle this?
Abin
[Updated on: Tue, 27 September 2016 09:22] by Moderator
Re: Dynamic Creation and Disposal of Channels [message #1745115 is a reply to message #1744499] Wed, 05 October 2016 06:49 Go to previous messageGo to next message
If you need to keep track of the lastest state, you should keep this value within your binding, yes.
Re: Dynamic Creation and Disposal of Channels [message #1745918 is a reply to message #1745115] Wed, 19 October 2016 06:21 Go to previous message
If the Thing's property which is being exposed by a channel can be changed from an external entity, what do you suggest to keep the channel value in binding fresh? Is polling a good option?
Abin
Previous Topic: Extra information in config XML files
Next Topic:LOG & EVENTS
Current Time: Tue May 13 22:56:06 EDT 2025
Powered by FUDForum. Page generated in 0.06122 seconds
